shoothing at baptism need help!!
Discussion in 'Photography Beginners' Forum' started by pokopelo, Apr 18, 2009.
  1. pokopelo
    pokopelo TPF Noob!
    Apr 7, 2009
    54
    north east, Mexico
    hello, í just got my Nikon D60 last thursday, haven't been able to shoot much since then, and my niece's baptism is tomorrow, my sister has hasked me to shoot but i am clueless about which setings to use in the camera, i was planning to go auto to avoid messing up, but even then i am unsure about what setting to choose. I only have the camera flash, so that might add to the issue... any help will be very much appreciatted... i think the church will have low light thanks for your help.
  2. nickisonfire
    nickisonfire TPF Noob!
    Dec 24, 2008
    278
    NYC
    well like you said the church will most-likely be dark so i would boost your ISO up to about 800 (you can go higher if you have a good noise filter on your computer)
    also shoot in aperture priority mode because your going to need to open your aperture as much as you can to let the light in
    i know some churchs won't allow flash so ask before using it, if they don't allow it you should be good with the tips i gave you above. if they don't let you use flash during the ceremony you could always ask the priest if he would mind just pretending to run through the ceremony after (sometimes they're cool and won't mind)
    thats it really, good luck
  3. EhJsNe
    EhJsNe TPF Noob!
    Nov 23, 2008
    617
    A Riverside Town by Canada
    Boost up the ISO to at least 400, 800 would be even better. If you can remove noise or dont mind it, go even higher.
    Set your camera to shutter priority, and set it to at LEAST 1/60, or you can set it to aperture priority and somewhere in the menues, i beleive, you can set the minimum shutter speed, im not exactly sure how.
    If the church allows for flashes, use it. You may want to buy a diffuser, or just use a less powerfull flash. (use the flash expsosure compensation)
  4. memento
    memento No longer a newbie, moving up!
    Jul 2, 2007
    699
    78
    Washington DC
    use your camera in auto mode and focus on the people;
    expressions,hugs,kisses,smiles..
    push the button when it's the right time.
    learning about photography is a long process.
  5. LuckySo-n-So
    LuckySo-n-So TPF Noob!
    Feb 2, 2009
    449
    Baton Rouge, LA
    I like this answer the best. This is no time to practice or experiment.
  6. pokopelo
    pokopelo TPF Noob!
    Apr 7, 2009
    54
    north east, Mexico
    thank you all for your kind comments... i guess i will shoot mostly auto to avoid any messups, and change at the end to try some out, otherwise how does one learn?
    hopefully I can share one or two that come out decent :lol:
    thanks again
  7. LuckySo-n-So
    Feb 2, 2009
    449
    Baton Rouge, LA
    Good luck to you!
  8. bdavison
    bdavison TPF Noob!
    Mar 5, 2009
    161
    Just a warning....in auto mode on the D60, it will pop the flash up automatically when you take a shot if it needs it.
    So be prepared. Id hate for you to walk in on a "no flash" service, and accidentally fire off a flash.
    If you still want the auto mode, but without the flash just turn the knob to "no flash" and shoot. Be aware that it might pick a slow shutter speed, so watch out for camera shake blur.
    Id shoot in aperture priority mode. f/5, let the camera pick the shutter speed, and use ISO 400 if possible. Watch your metering for correct exposure. And use PRE mode for the white balance.
