Shooting Pictures without Blowing out the Background
Discussion in 'Photography Beginners' Forum' started by PhotoJunkieJen, Sep 15, 2008.
  1. PhotoJunkieJen
    PhotoJunkieJen TPF Noob!
    Sep 11, 2008
    49
    Hey guys... I'm looking for some tips on how to properly expose a foreground without blowing out a bright background.
    For instance, we little to eat at a waterside restaurant and take pictures there. How can I take a decent picture of my parents sitting inside the restaurant using a flash... without blowing out the sky behind them?
  2. reg
    reg TPF Noob!
    May 28, 2008
    1,487
    Stuck inside of Mobile with the GTFO Blues Again
    Meter for the sky, use the flash to fill in the interior.
  3. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
    The idea is to have more light on your subject than in the sky, basically. You want to err on the side of underexposing the sky to get the blues. That can be VERY hard to do, because even an overcast sky tends to be far brighter than any source of artificial light.
    If you can, it's best to have the sun to your back, but it sounds like in the situation you are in that's essentially impossible. As reg said, try the flash.
  4. PhotoJunkieJen
    Sep 11, 2008
    49
    Are there any sort of filters that could be used in a sitation like that?
  5. reg
    reg TPF Noob!
    May 28, 2008
    1,487
    Inside the restaurant.... how much sky is there in the scene anyway? A small square or two? 25%? The entire background?
  6. PhotoJunkieJen
    Sep 11, 2008
    49
    Well for this particular restaurant, it's open air... so it's basically you... the table and the sky, haha.
    But I'm also lookking for any general advice for shooting in a situation like this... For instance, shooting into the sun but not wanting to silhoutte the foreground.
  7. reg
    reg TPF Noob!
    May 28, 2008
    1,487
    I'm telling ya, spot meter on the sky, and use the flash to compensate for the foreground.
  8. K8-90
    K8-90 TPF Noob!
    Mar 18, 2008
    937
    16
    CANADA
    ^ +1
  9. jwhphoto
    jwhphoto TPF Noob!
    Sep 12, 2008
    40
    Citrus Heights, CA
    I haave a question along these lines, What if your subject is somewhat far away and the flash has little effect on this? is there any way to keep the sky from blowing out?
  10. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    Then you may need to use a tripod and take few shots with different exposure settings such as bracketing and combine them together later with software.
  11. chrisburke
    chrisburke TPF Noob!
    May 25, 2007
    2,107
    Madoc, Ontario Canada
    The Sunny 16 rule...
    the rule tells us on a bright sunny day to set your aperture at f 16 and convert the ISO film rating to the closest shutter speed.
    Example would be: f/16, ISO 400, Sutter 1/400
    or
    f/16, ISO 100, Shutter 1/100
  12. ANDS!
    ANDS! No longer a newbie, moving up!
    Nov 14, 2006
    2,178
    Downtown
    What the hell?
    As others have said, meter for the sky, and if you have a flash, use that to "fill in" the light for your subject (which would be WAY underexposed otherwise). If no flash is available, simply say "screw you" to the sky, and focus on your subject. If you can, position yourself so the overexposed sky is NOT in the shot.
    Basically -work with what you've got.
how do i photograph a subject with a bright backgound without blowing out background
