Shooting the moon & avoiding glare
Discussion in 'Photography Beginners' Forum' started by padrepaul77, Nov 2, 2009.
  1. padrepaul77
    padrepaul77 TPF Noob!
    Jan 28, 2009
    155
    Twin Cities, MN
    I was trying to shoot the moon over the cathedral last night. Unfortunately, there was a bit of glare; I'd like the moon to look smooth. Is this caused by the UV filter being on the lens? Or simply because it's a 40-second exposure and the earth is moving so the moon has slightly moved in those 40 seconds? Any suggestions?
    [​IMG]
  2. Turnerea
    Turnerea TPF Noob!
    Aug 28, 2008
    212
    SoCal
    I'm sure some more experienced folks will comment as well, but yes... 40 seconds at pretty much any setting will greatly overexpose the moon, and that is definitely long enough to allow the moon to move through your picture.
    I read someone on this forum had come up with the rule of thumb that your shutter speed has to be faster than 600/35mm equiv focal length. For estimate sake, let's say you're at 100mm 35mm equivalent, that'll give you a max shutter speed of 6 seconds. I believe this was developed for star trails, so the moon, being a whole lot closer, would require an even faster shutter speed.
    The UV filter may cause some additional reflections as well, but your shutter speed is the main problem I believe. Should ditch the filter for night shooting though.
    The moon is difficult to capture without silhouetting everything else around it...
  3. padrepaul77
    Jan 28, 2009
    155
    Twin Cities, MN
    Thanks for the tips; though if I lower the shutter speed the moon might look good, but wouldn't the top of the cathedral be underexposed then? I like the exposure on the cathedral in the pic. Tough situation.
  4. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    Not much you can do about that...unless you can add more light to the cathedral. Remember, the moon is being lit by direct sunlight....so it's basically as bright as anything would be at noon on a sunny day here on earth.
    For something like this, you could take two shots and just combine them later.
  5. pkirchner
    pkirchner TPF Noob!
    Nov 2, 2009
    40
    Asheville, NC USA
    Take two shots, one of the church another of the moon. Combine them in PS. The moon will be properly exposed using this method. Also loose the uv filter. Pete
  6. KmH
    Apr 9, 2009
    40,756
    5,588
    Iowa
    The Moon only reflects about 11% of the Sunlight that hits it. The technical term is albedo.
    Still, it's WAY brighter than the cathedral, and as mentioned the cathedral doesn't move in a 40 second time span, but the Moon did.
    Oh ya......+1 on loose the UV filter, but make sure you have the lens hood on.
  7. Dwig
    Dwig TPF Noob!
    Mar 11, 2009
    1,261
    Key West FL
    That would be "raise the shutter speed", not "lower ...". But yes, setting the correct exposure for the moon would undoubtedly result in an underexposed cathedral.
    The solution is to take two exposures, one set for the moon and one for the cathedral, just as you made in your example. It would then be a simple matter to composite them in Photoshop, each on a separate layer, and use a layer mask to mask out the mis-exposed portion of the upper layer.
    Back in ancient times when people used film :) the technique was to setup the camera and shoot the first exposure for the moon. You would then wait, preferably with a flashlight & good book to read, for a few hours until the moon moved out of the frame. You could then make a second exposure on the same frame (required a camera that allowed double-exposures with perfect registration) to get the proper exposure for the cathedral.
  8. eric-holmes
    eric-holmes No longer a newbie, moving up!
    Aug 8, 2009
    1,858
    49
    Arkansas
    When I shoot just the moon, I have to use a shutter speed of ~1/250 or faster to get good detail of the moon without it being blown out.
  9. pkirchner
    pkirchner TPF Noob!
    Nov 2, 2009
    40
    Asheville, NC USA
    As I understand it, digital sensors cannot see uv light. This is a carry over from the old film days. Film can be sensitive to uv light but not digital cameras. So toss the uv filter, the more glass on your lens the better the chance for unwanted flare.
  10. Inst!nct
    Inst!nct TPF Noob!
    Sep 16, 2009
    702
    Troll, Wisconsin
    couldn't you take a picture with a fast shutter speed (for the moon)
    and a picture with a low shutter speed (for the cathedral)
    and photoshop them together?
    • Like Like x 1
  11. lawrencebrussel
    lawrencebrussel TPF Noob!
    Jul 18, 2011
    34
    Netherlands
    i guess Big Mike is right. You won't get both in single exposure because light difference between a bright moon and cathedral is large. It's really difficult job to get the moon and the earth objects in the same exposure. :grumpy:
  12. 480sparky
    480sparky Chief Free Electron Relocator Supporting Member
    Mar 8, 2011
    22,744
    8,137
    Iowa
    The moon is simply another sunlit object, just like taking a photo of anything sunlit here on this planet. So exposures of the moon is the same as exposures of the kids in the back yard.
how remove photo glare from the moon
how to get rid of lense flare when shooting the moon
how to remove flare while taking moon pic
how to stop reflection of the moon when taking a photo
how to take a picture of the moon without a glare
how to take a picture of the moon without glare
how to take picture of the moon with out glare
how to take pictures of the moon without glare
moon lens flare
photograpy moon flaring
