Shooting with a flash
Discussion in 'Photography Beginners' Forum' started by timfrommass, Dec 17, 2009.
  1. timfrommass
    timfrommass TPF Noob!
    Aug 20, 2009
    182
    I have a lot more work to do in terms of my composition and general exposure before I really dig into lighting, but I have a basic flash question. When I use either my in camera flash (on the D90) or my Dad's old SB-24 which I tried out for the first time yesterday I'm limited to 1/200sec exposure time. Is there a way to remove this limitation? If not what's the reason for it?
    -tim
  2. Goontz
    Goontz TPF Noob!
    Jul 17, 2009
    1,275
    Austin/Houston, TX
    1/200 shutter is the flash sync speed for the D90, so you won't be able to go any faster than that while using a flash. Let me poke around for a moment and hopefully I can find a video that another user has posted here before that should be very helpful.
  3. Village Idiot
    Mar 20, 2008
    7,274
    406
    There's a high speed sync option you should be able to use though. That makes the flash pulse in the time that the shutter curtain is open to get a full exposure. You really lose power with an HSS mode though.
  4. Goontz
    Goontz TPF Noob!
    Jul 17, 2009
    1,275
    Austin/Houston, TX
    This is the video that I was looking for. It does a good job of explaining sync speed.
  5. KmH
    Apr 9, 2009
    40,546
    5,542
    Iowa
    The reason for it is the way the shutter works.
    The shutter is actually 2 curtains. nikon calles them the front and rear curtain.
    At 1/200 both curtains are open all the way. At faster shutter speeds the curtains form a moving slit. The slit is narrowest at 1/4000 second.
    To do flash at shutter speeds higher than 1/200 the camera and flash have to be capable of FP sync mode.
    FP sync mode fires the flash several times during an exposure and will significantly speed the depletion of battery power and lengthen re-cycle times.
  6. NateWagner
    NateWagner TPF Noob!
    Jun 2, 2008
    1,240
    St. Petersburg, FL
    HSS (or I guess FP sync mode) also dramatically reduces the power of the flash.
