Shots with the Nikkor 35mm f/1.8 AF-S
Discussion in 'Photography Equipment & Products' started by Santa Gertrudis, Feb 25, 2010.
  1. Santa Gertrudis
    Santa Gertrudis TPF Noob!
    Feb 9, 2010
    321
    San Marcos, Texas
    Who's got em? Let's see em!
    Thanks! :D
  2. JimmyO
    JimmyO TPF Noob!
    Feb 3, 2008
    2,132
    NJ
  3. Santa Gertrudis
    Feb 9, 2010
    321
    San Marcos, Texas
    Thanks, Jimmy! Those are damn sharp!
  4. epp_b
    epp_b No longer a newbie, moving up!
    Aug 22, 2008
    2,135
    12
    True North Cold and Freezing
    Yay, another chance to pimp my stuff :mrgreen:
    Wide open at f/1.8:
    [​IMG]
    [​IMG]
    If you're wanting to get this lens... do it. It's sharp everywhere, even wide open. Some say that it has some CA wide open, but the only faults I've been able to find are simple, 100% correctable barrel distortion and a bit of ghosting when shooting into bright light sources.
  5. Santa Gertrudis
    Feb 9, 2010
    321
    San Marcos, Texas
    Very nice shots!
  6. dhilberg
    dhilberg TPF Noob!
    Jul 26, 2008
    516
    Washougal, WA
    I've held off getting this lens because it has quite a bit of distortion, but if what you say is true I may have to look more seriously at this lens. I need a 35mm as my 50mm is a bit tight for indoor stuff unless there's plenty of room. I was considering the 35mm f/2 AF-D but it's quite a bit more expensive.
  7. manicmike
    manicmike No longer a newbie, moving up!
    Sep 29, 2009
    1,224
    307
    Oregon
    [​IMG]
  8. JimmyO
    JimmyO TPF Noob!
    Feb 3, 2008
    2,132
    NJ
    IT does have a bit, but its still better then pretty much all zooms. Also when is a tad bit of distortion really gonna ruin a photo? If you are shootings something you need PERFECT you can always correct it in photoshop no big deal
  9. The Shoe
    The Shoe TPF Noob!
    Jan 10, 2010
    87
    British Columbia
    The only issue I have with the lense, although it may be a camera issue, is manually focusing. I find it hard to get a spot on focus through the viewfinder, but I'm used to an older SLR. So I'm sure I will get better.
    Couple shots from around a week of use, unedited save for being shrunk:
    [​IMG]
    [​IMG]
  10. sleist
    sleist Been spending a lot of time on here!
    Nov 8, 2009
    3,610
    1,850
    Boston
    For $200 it's not bad. I have this and a 50mm 1.8 and prefer the 35mm for indoors, informal snaps on my DX. That being said, I'm likely going to get a wide angle zoom next. If it's a 12-24, I may get rid of the 35. The purple fringinging is pretty bad under the right/wrong circumstances and on a DX I keep finding it either not wide enough or not close enough. I think on a DX the 35mm prime is a bit limited.
  11. KmH
    Apr 9, 2009
    40,533
    5,541
    Iowa
    For the price it's worth having in the bag, and I have one.
    The lens is nicely sharp in the center but sharpness drops off rapidly as you move towards the edges, particularly wide open. The sharpness falloff towards the edges is not as dramatic at apertures smaller than f/10, but by then the lens sharpness will tend to be less than the resolving power of the image sensor.
    The center sharpness meets or exceeds the resolving power of today's image sensors from about f/2.2 to f/10, but sharpness still falls below the sensor resolving power as you look further away from the center of an image.
    This can be problematic if you're wanting to use compositional techniques that avoid having your main subject at the center of the frame.
    So like most lenses, if you want tack sharp focus, keep the lens off maximum and minimum aperture and use careful composition.
  12. c&k
    c&k TPF Noob!
    Feb 23, 2010
    21
    The Great State of Alabama
    I've been thinking of ordering one of these in a few months right before my baby comes. Thanks for posting some images taken with this lens.
