Should I cover the eye piece?
Discussion in 'Beyond the Basics' started by 250Gimp, Mar 6, 2007.
  1. 250Gimp
    250Gimp TPF Noob!
    Oct 3, 2006
    1,031
    Chelsea, Quebec
    I was wondering if I should cover the eyepiece of my camera when I don't have my eye to it, such as when I am taking timed shots, or using mirror lock up? It is a pain to put the little cover on and off to recompose each shot.
    I figured some of the local experts could help me with this question. :sexywink:
    Thanks
  2. shingfan
    shingfan TPF Noob!
    Dec 29, 2006
    569
    Toroto, ON
    with long exposure....for sure it is a good idea to cover it up.....but for shorter exposures such as 1/60......i also like to know if it makes a difference
  3. Big Mike
    Dec 16, 2003
    33,854
    1,818
    Edmonton
    I know that my Canon camera strap comes with a little eye-piece cover...but I don't think I've ever actually used it.
    Light can get into the camera though the viewfinder...and that light could cause problems like a loss of contrast etc. Normally, I probably wouldn't think of it...but if it's really bright or if there is direct sun light coming from behind the camera...and it's on a tripod (I'm not looking though it)...then I would probably just cover it with my hand or hat, without touching it. If it was a fairly long exposure...then that's when the cover would come in handy.
  4. Mike_E
    Jan 26, 2007
    5,327
    266
    If it's light out or light in the room and you are taking special care with the exposure or are using Lots of studio flash (or so I'm told) -yes. The light can go either way to the mirror and effect the meter. mike
  5. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Even though the manual of my D200 says I should do this I have never done it. Even when I took a 25second exposure with the cable release, realising while I was taking it that a streetlight was shining directly into the viewfinder there was nothing wrong with the image. No exposure, contrast, or other problems.
  6. EOS_JD
    EOS_JD TPF Noob!
    Feb 15, 2007
    1,698
    I have in fact used the eye cover on my 20D strap. I was taking some image on a red lit bridge. I was shooting over towards another bridge lit blue. When I got home all my images had red flare showing in the water. My exposures were between 10 and 30 seconds long.
    I had to use photoshop to get rid of all the flare circles but I quickly found out that it was caused by red light coming through the eye peice and into the lens.
    Any lighting that is close by in line with the camera eyepeice is a cause for concern, especially for longer exposures. For shorter I don't think I'd be too worried. You may see some flare you can't explain though and this may be the reason!!
    Sometimes putting the cover on is a pain and I do as Mike does. Cover with your hand without touching the camera.
    Cheers
    JD
  7. xfloggingkylex
    xfloggingkylex TPF Noob!
    May 5, 2006
    1,292
    Frederick, MD
    are you sure that color bleed wouldn't have been caused simply from shooting from a location that is lit a different color? I wonder how much the eye piece would help your problem. If you have done this, comparison photos would be excellent!
    I never bother with the viewfinder cover.
  8. EOS_JD
    EOS_JD TPF Noob!
    Feb 15, 2007
    1,698
    Used the hood on my Tamron 17-35 so that I wasn't getting styray light (but you may be right with this). It's not the best of hoods.
  9. Don Simon
    Don Simon TPF Noob!
    Jul 4, 2005
    2,484
    I have never felt the need to cover the viewfinder except when the exposure was long (minutes at least), and as far as I can tell it's never affected my exposures, film or digital. I understand some may want to err on the side of caution but this is the first time I've heard it suggested for anything faster than a second. In other words, no I really don't think it's necessary, but then again I don't know about your camera so don't sue me if you take my advice and lose the shot of the century ;)
  10. 250Gimp
    250Gimp TPF Noob!
    Oct 3, 2006
    1,031
    Chelsea, Quebec
    Thanks for the answers everyone. Most of the shots I will be doing are short exposure, so i guess I will just decide based on the light in the area I am shooting.
    Cheers
  11. Patrice
    Patrice No longer a newbie, moving up!
    Dec 6, 2006
    2,392
    381
    Campbellton, New Brunswick, Canada
    I lost that pretty quickly. I now keep a bit of black electrical tape in the camera bag. My F4s has a lever in the vf to close it. Got in the habit of doing that when on a tripod as the meter is affected by light through the vf, at least on the F4s it is.
  12. neea
    neea TPF Noob!
    Nov 27, 2006
    710
    Canada
    And here all this time I thought it was there to protect the viewfiner when you're not using the camera. I had no idea light could get in through there. Of course I've never put an ounce of thought into it but it makes sense now.
    I believe i still have the one on the strap but I lost the little cushion years ago!
canon eyepiece cover
canon eyepiece cover on strap
canon strap with eye cover
cover eyepiece with remote
eyepiece cover
eyepiece cover for canon
eyepiece cover on canon strap
how to cover eyepiece
how to cover viewfinder thru canon strap
what is the eyepiece cover on canon strap used for?
