Should I get a polorizing filter?
Discussion in 'Digital Discussion & Q&A' started by hotrocks, Jan 12, 2008.
  1. hotrocks
    hotrocks TPF Noob!
    Jan 12, 2008
    160
    Baltimore, MD
    So I have a FujiFilm Finepix S7000...I took a lot of pictures in Israel and a lot of them have the sky in it, and I notcied that I could use a polarizing filter..the thing is that my camera isnt a DSLR.....its close to one tho.....so I'm not sure how/which kind of filter i need and if it would work.....
  2. RKW3
    RKW3 TPF Noob!
    Apr 30, 2007
    1,716
    So Cal
    Find out the mm of your lens, then get a polarizer that fits those mm.
    And yes, polarizers are worth it if you plan on taking a lot of outdoor shots.
  3. hotrocks
    hotrocks TPF Noob!
    Jan 12, 2008
    160
    Baltimore, MD
    well since my camera isnt a dslr it needs an adapter thats like 30$....and its a 55mm...so i can get a polarizing filter for like 15-20$? right?
    also..what about wide angle/ teleconverters......would you suggest those
  4. peterbj7
    peterbj7 TPF Noob!
    Jan 21, 2008
    118
    Oxford UK and Belize
    Whatever it costs, it'll transform land/seascapes. Skies will look better than you've ever seen. I quite often shoot with a compact through polarising sunglasses, not perfect but the best I can do as there's no way of fitting a filter.
    My DSLR has a polarising filter permanently attached.
  5. airgunr
    airgunr TPF Noob!
    Mar 21, 2004
    846
    4
    Delavan, Wisconsin, USA
    Polarizing filters will remove reflected light from windows, water, etc. It will not do that with metal reflections. It will also intensify the blues in the sky.
    It's effectivness will depend upon the angel of the sun to your subject. 90 degrees is the most effective.
    The best way to select a filter is to find the mm size of your largest lens and get it in that size. Mine is 77mm so I got that size.
    For smaller lenses you can get step-up rings so it will fit the filter. This is a good idea for any other filter as well.
    I would not buy the cheapest one you can get. You will regret it and in the end buy a better one anyway. Buy the best you can afford. B&W, LEE, Singh Ray, etc.
    IMHO, the polarizer is the first and main filter you should get. Make sure it is a "Circular" polarizer.
    PS - I just realized that you don't have a DSLR so the size issue is moot. Just get it in the size for your camera.
  6. jbhinojosa
    jbhinojosa TPF Noob!
    Feb 1, 2008
    16
    Texas
    I just got a nikon D80 and now i need polarizer filter. I'm not sure if a circular CPL polarizer filter would be right for it or a linear.
    Any suggestions?
  7. skieur
    skieur TPF Noob!
    May 14, 2007
    5,076
    203
    Canada
    Circular for all uses.
    skieur
  8. MichaelT
    MichaelT TPF Noob!
    Jan 18, 2008
    95
    Washington State
    When you look through the viewfinder, isn't the image you see the same as what is coming through the lens? As long as it is, you can adjust the filter for the correct orientation. If not, you have a problem using a polarizer.
  9. jedithebomber
    jedithebomber TPF Noob!
    Oct 3, 2007
    153
    Cottonwood, AZ
    I would suggest taking the money you would spend on adapters and filters and putting it aside for an eventual upgrade to DSLR. However if you expect to keep this camera for a long time, you may find the various attachments worthwhile.
  10. kidchill
    kidchill TPF Noob!
    Jan 27, 2008
    249
    Brooksville, FL
    Don't waste your time with a linear filter!! Even if you have a TTL vue...use a circular and it won't matter!! Do a search on popphoto.com about filters. It'll tell you why you need it and how it works....CHRiS
  11. Tennessee Landscape
    Tennessee Landscape TPF Noob!
    Jan 19, 2008
    580
    Seymour, TN
    I bought UV filters for both my lenses, and polorized filters....I leave the UV's on all the time,...ALL the time to protect to coating on the lenses. They're glass too....they don't sctratch....I think these are the two most important filters to have....
  12. runnin9z
    runnin9z TPF Noob!
    Feb 7, 2008
    12
    Centreville or Norfolk VA
    Yes for the types of pictures you are talking about a circular polerizer would have been very useful, i love mine.
can i keep a polorizing lens on my camera all of the time
