Should you use vibration reduction/image stabilization on a tripod?
Discussion in 'Macro Photography' started by JbleezyJ, Aug 30, 2010.
  1. JbleezyJ
    JbleezyJ TPF Noob!
    Aug 21, 2010
    103
    San Jose
    when doing macro shots with a wired remote? I hear people say that you should keep the vibration reduction on still even if the camera is mounted on the tripod. I also hear people say that you should turn it off or it will actually shake the camera a bit. So what do you think and why?
  2. Arkanjel Imaging
    Arkanjel Imaging No longer a newbie, moving up!
    Jun 8, 2009
    1,229
    157
    SW Florida
    There is much controversy on this subject. Both for and against. What Ive gathered is that its the older IS that were unreliable on a tripod. The new systems supposedly can tell when they are tripod mounted. Ive seen zero difference keeping it on with either of my VR Nikon lenses (18-200 and 105.) As a genreal rule of thumb, if Im shooting shutter speeds between 1/15-1/500 I use it. Over or below that and the math doesnt seem to work. Some business about the frequency (Hz) of muscle vibrations on the high end. And on the low end the exposure is so long the IS cant comp for it.
    If you read 100 threads/articles about this you will end up with 50 advocates for each. So take my two cents with minor consideration. Im no scientist. Heck, Im not even very smart. :er:
  3. Robin Usagani
    Robin Usagani Been spending a lot of time on here!
    Jun 6, 2010
    10,348
    2,175
    Denver, CO
    I also heard it is smart enough to turn it self off when it is not moving.
  4. AdrianC
    AdrianC TPF Noob!
    Aug 1, 2010
    155
    Edmonton
    You should turn it off when on a tripod. Newer VR technology is designed to detect the use of a tripod, however older VR lenses may create some vibration when they are set on a tripod.
should i keep vr on
should i use vibration reduction on nikon camera at all times
should you use vibration reduction
should you use vibration reduction on a tripod
vibration reduction macro
vibration reduction on tripod
vibration reduction tripod
when not to use vibration reduction
why does shake reduction not work on tripod
