shouldn't I see the f-stops?
Discussion in 'Photography Beginners' Forum' started by sarallyn, Feb 22, 2008.
  1. sarallyn
    sarallyn TPF Noob!
    Feb 21, 2008
    552
    4
    New England
    Hey everyone -- complete noob here (I've only ever used a sony cybershot dsc-650).
    I just inherited a canon ae-1 (film camera... it's old, too) with a 35-135 mm f/3.5-4.5 lens.
    My problem is that when I took the lens off and adjusted the f-stops, I couldn't see the hole widen or become smaller. When I look through the lens and adjust the f-stops, it looks like it just stays on the maximum aperture.
    Is it supposed to be like that?? Is this a complete noob question, or is there something wrong? I'll be developing my first roll of film from it this weekend... I'll see how it turns out (probably absolutely horrible).
    Thanks.
  2. petey
    petey TPF Noob!
    Oct 14, 2007
    311
    could it be locked?
    on Nikon AF lenses there is a little switch.
  3. Big Mike
    Dec 16, 2003
    33,847
    1,817
    Edmonton
    I believe that the aperture remains at it's widest, until you trip the shutter. That's how modern lenses/cameras work.
    Remember that you are looking though the lens when you look into the viewfinder. If the lens stopped down before the exposure, the viewfinder would get darker and harder to see, as less light was allowed in.
    This is also why some cameras have a DOF preview button. It stops down the aperture so that you can preview the DOF...but of course, it makes it darker.
  4. sarallyn
    sarallyn TPF Noob!
    Feb 21, 2008
    552
    4
    New England
    nope -- I don't think it's locked. I can turn and switch to different f-stops, but nothing will appear in the lens.
    one thing I just noticed when I took the lens off is that when I switch to different f-stops there is a little metal part on the base of the camera (that fits into the camera when the lens is one) that will move from side to side as I change the aperture.
  5. sarallyn
    sarallyn TPF Noob!
    Feb 21, 2008
    552
    4
    New England
    hmm... I know the camera is from the 60s or 70s, and I'm sure the lens is pretty old, too.
    but I think you're right... I'll have to see how my prints come out.
  6. Socrates
    Socrates TPF Noob!
    Jan 28, 2008
    1,183
    Exit #5
    Darned right, it's old. Brings back memories. I had the AE1-P, a slightly upgraded version. In any event, with the lens off the camera, I don't think you'll see the aperture change. This is because you're always composing the shot with the lens wide open (there isn't enough light for the human eye when the lens is stopped down). When you press the shutter button, the lens stops down to the desired setting and the pic is taken. The lens immediately opens up again.
    As I recall, there is a switch on the lens that will stop down the lens. It's intended to allow the photographer to view depth of field.
  7. Socrates
    Socrates TPF Noob!
    Jan 28, 2008
    1,183
    Exit #5
    I responded before I read your post. You're exactly correct.
  8. snaremop
    snaremop TPF Noob!
    Sep 9, 2006
    289
    Los Angeles
    There's definitely nothing wrong.. my new D40 does that as well.
  9. sarallyn
    sarallyn TPF Noob!
    Feb 21, 2008
    552
    4
    New England
    alright, awesome!! glad there's nothing wrong. thanks for the responses!
  10. Early
    Early TPF Noob!
    Feb 8, 2008
    1,240
    Western NJ
    It sounds like lube oil is leaking onto the aperture blades making them stick open. Flick the lever in back of the lens. It should close down with that. Regardless, it will need servicing unless you want to use it wide open all the time. Of course, that doesn't work with the AE-1 since it is a shutter priority based camera.
  11. sarallyn
    sarallyn TPF Noob!
    Feb 21, 2008
    552
    4
    New England
    The lever moves when I adjust the aperture; I think it's what the others suggested (the f-stop will close with the shutter).
  12. Early
    Early TPF Noob!
    Feb 8, 2008
    1,240
    Western NJ
    With the lens off the camera, you should see the aperture blades close when turning the aperture ring.
canon ae-1 f-stops
