Shutter Speed for Football
Discussion in 'Photojournalism & Sports Gallery' started by IDLaxStar, Sep 12, 2010.
  1. IDLaxStar
    IDLaxStar TPF Noob!
    Feb 28, 2010
    174
    Idaho
    What do you guys think is the minimum speed you should be shooting football at? Also what is the ideal speed to be shooting at?
  2. Hooligan Dan
    Hooligan Dan No longer a newbie, moving up!
    Mar 10, 2008
    536
    85
    Bay Area, CA
    You'll want to stay above 1/250th. Even then you mad risk a little motion blur on hands and feet and when the ball is thrown.
    That's for night games, btw. Day games you won't have any problem shooting at 1/1000 or faster.
  3. CNCO
    CNCO TPF Noob!
    Feb 4, 2010
    488
    7
    USA
    dont take this the wrong way but what age group? with pop warner you would shoot a lot different than pro's.
  4. bigtwinky
    bigtwinky No longer a newbie, moving up!
    Oct 6, 2008
    4,820
    285
    Montreal
    I was doing soccer at around 1/500th and it was fine. Depends on what part of the action you are shooting... running, sprinting, blocking, tackles...each moment has a peak where it is somewhat slower and you can get away with a slower shutter... take a QB dropping back for a pass, he puts his arm back for a pass...it hits a peak going back right before it goes forward..
  5. IDLaxStar
    IDLaxStar TPF Noob!
    Feb 28, 2010
    174
    Idaho
    I will be shooting High School level. Also thanks for the tip about shooting it right at the so called peak of the action. I will try to do that.
  6. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    40,465
    15,207
    USA
    It also depends on how the action is oriented toward the camera...on shots coming right AT the camera, or straight away from it, slower shutter speeds will stop motion adequately well...but action that is moving at right angles to the camera will require higher shutter speeds...a running back in the backfield and taking a handoff and running down the line and right toward the camera position can be "Stopped" with a moderate speed...a guy streaking right down the sideline with the camera up close to the action will require a much,much faster shutter speed for an adequately stopped-looking picture. If the games are at night, when most varsity games are, you probably will be stuck somewhere between 1/180 and 1/500 at f/2.8 at ISO 3200 at many HS fields. Often, the field will have poor illumination evenness as well...often mid-field to the 20 is decently-lighted, but the goal line and end zone areas are like The Abyss.
  7. CNCO
    CNCO TPF Noob!
    Feb 4, 2010
    488
    7
    USA
    are you allowed to use a flash?
  8. IDLaxStar
    IDLaxStar TPF Noob!
    Feb 28, 2010
    174
    Idaho
    I couldn't tell you if you are or are not. But I don't have a separate flash. Would the flash on your camera work?
  9. Sam6644
    Sam6644 TPF Noob!
    Nov 18, 2009
    248
    Cincinnati, Ohio
    I'll up my ISO until I can do atleast 500.
    I shoot for newsprint and the 7D noise control is good enough to let me do that though, your result may vary.
best shutter speed for football
minimum shutter speed for football
shutter speed for football games
what should my shutter speed be at for a football game
what shutter speed should be used for football game
