Shutter Speed Photography
Discussion in 'Photography Beginners' Forum' started by Someone838, Mar 8, 2009.
  1. Someone838
    Someone838 TPF Noob!
    Mar 8, 2009
    5
    When I put my shutter speed on "blub", leave the shutter open and take pictures of myself in multiple locations during the same shot by covering up the lens while I'm moving, what is that called?
    Also, I've noticed that I am very faded in the photographs that come out, is there a good way to fix this? The only way that I have figured out is to use a black background, but if possible I would like to take these kinds of photos outside as well.
  2. hankejp
    hankejp TPF Noob!
    Aug 24, 2008
    608
    Wausau, Wisconsin
  3. Someone838
    Mar 8, 2009
    5
  4. Someone838
    Mar 8, 2009
    5
    Nevermind, I noticed that he used photoshop for those photographs. Is there anyway to do that kind of photography without photoshop?
  5. Katier
    Katier TPF Noob!
    Jan 14, 2009
    452
    You can't get around the ghosting doing it the way you want to do it.
    The example shown is heavily photoshopped. He's taken multiple shots from exactly the same view point then used one shot ( probably one without him on the frame ) as the background then cut and pasted just the bits of the photo containing him and pasted it into the right part of the background.
  6. Katier
    Katier TPF Noob!
    Jan 14, 2009
    452
    There IS a way you could do it without photoshop.. but it would require a lot of cleverness using masks in a dark room ( and of course been taken on film ).
  7. Someone838
    Mar 8, 2009
    5
    That's what I was afraid of. I've taken a couple of shots that have turned out really well, but they all had black backgrounds.
    I'm thinking I might be able to do it at night also. That's what I'm going to try, but I was hoping there was a way I could do it during the day also.
  8. Ptyler22
    Ptyler22 TPF Noob!
    May 23, 2008
    789
    Massachusetts
    You could try using a flash, or get someone to turn on a really bright light for a second, that might work, never tried it though
  9. Overread
    May 1, 2008
    23,682
    4,028
    UK - England
    only way I can think of getting it to work with a single exposure would be with a dark room and a black background - or a very very dark night -and a flash with either second shooter or a flash remote.
    Setup the camera with bulb shot and take the shot - the black surroundings mean that no light will be getting in so you can move to the location without any ghosting - then fire the flash once to expose yourself on the camera with the light - repeat for other positions then close the shutter.
    It will take some experimenting to make sure that the flash power is at the right exposure level for your shots of course.
    Outside might be possible, but you will have to have the flash light focused very much on yourself (or have a very distant backdrop) so that you don't get the flash light exposing background areas two or three times over (and thus overexposing).
  10. Someone838
    Mar 8, 2009
    5
    I'll give some of these ideas a try. Thanks for all of your suggestions.
  11. Jaszek
    Jaszek No longer a newbie, moving up!
    Oct 7, 2008
    2,177
    30
    Brooklyn, NY
    Even with the flash you get some ghosting.This is 30 second exposure. When the flash fired I moved away. If the exposure wouldn't be so long I wouldn't be as ghosty. Day Fourtytwo on Flickr - Photo Sharing!
  12. Ptyler22
    Ptyler22 TPF Noob!
    May 23, 2008
    789
    Massachusetts
    Ya, it will still give some ghosting but not nearly as much as it would without
