Shutter Speed Question
Discussion in 'Beyond the Basics' started by Stratocaster, Feb 10, 2008.
  1. Stratocaster
    Stratocaster TPF Noob!
    Nov 27, 2007
    Hey.
    After recently purchasing a Hoya ND400 (awesome), I've been playing around with long exposure times. Now, I'm using a Canon EOS 350D, and I was wondering if there was any way of reducing the shutter speed to a value past 30 seconds?
    I'm sure you'll know that if you try to go for a longer time, it will display the message 'bulb'. What does this mean exactly?
    Any help is appreciated. ;)
  2. HASHASHIN
    HASHASHIN TPF Noob!
    Mar 1, 2007
    414
    NYC
    the bulb function is so you can manually set the shutter speed by holding down the shutter button
    you use it for anything over 30 seconds on your camera. use a wired shutter release for this so you dont get the camera shake while you are holding the button down.
  3. yeti
    yeti TPF Noob!
    Jan 8, 2008
    115
    It means your camera won't count past 30 seconds, so it lets you to time it externally. As long as you keep the shutter button down, it will keep the shutter open. When you let go of the button, the shutter closes.
  4. John_Olexa
    John_Olexa No longer a newbie, moving up!
    Feb 3, 2008
    436
    49
    Maryland
    Yep! I shoot lightning for stock . I wouldn't even bother if my camera didn't have a bulb setting!
  5. Socrates
    Socrates TPF Noob!
    Jan 28, 2008
    1,183
    Exit #5
    The question has already been answered but I figured that I'd add a bit of history. The setting goes back probably a hundred years when it was not possible to synchronize the flashbulb to the shutter opening. Consequently, the photographer had to open the shutter, manually fire the flashbulb and then close the shutter. Hence "bulb."
  6. BYoung
    BYoung TPF Noob!
    Jan 4, 2008
    163
    Northwest Territories, Canada
    Somehow I totally messed up my understanding of the "bulb" setting for shutter speed. It's good to know that it can be open for longer then 30 seconds.
  7. Stratocaster
    Nov 27, 2007
    Ah, I see. Thanks for the help guys. It's appreciated. ;)
  8. RacePhoto
    RacePhoto TPF Noob!
    Dec 29, 2006
    562
    5
    Wisconsin
    You mean it's not because they had a rubber tube, with a BULB on the end, and squeezed the bulb, which would hold the shutter open? I always thought that's what it meant? Hmmmm?
    T is for Time, in which case, you would push the shutter release and it would stay open, until you pushed it again.
    Both have the same effect, just two different ways to get there.
  9. Socrates
    Socrates TPF Noob!
    Jan 28, 2008
    1,183
    Exit #5
    Now you've got me wondering. I honestly don't know. You may well be correct.
  10. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    Hell's Kitchen, New York
    So did I. I thought that the 'bulb' setting predated the invention of the flash bulb.
    Best,
    Helen
  11. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    It did, as far as all my readings and experience told me as well.
  12. Jon, The Elder
    Jon, The Elder TPF Noob!
    Jul 10, 2007
    376
    Southeastern Michigan
    It does. Many medium and large format cameras were equipped with a 'bulb' and tube to keep the shutter open.
