*Sigh* Another Lens Question
Discussion in 'Photography Equipment & Products' started by danpclements, May 4, 2007.
  1. danpclements
    danpclements TPF Noob!
    Apr 13, 2007
    19
    Littleton, Co
    For starting out in photojournalism and trying to build a portfolio, what do yall think would be better: Canon 24-70 F/2.8L OR Sigma 24-70 F/2.8 and Sigma 70-200 F/2.8. I don't know if I should want the best glass I can, or get two lenses to cover more situations. At the moment, I'm leaning toward getting the two sigma's but would like input from people with more experience.
  2. Seefutlung
    Seefutlung TPF Noob!
    Apr 13, 2007
    1,558
    62
    SoCal
    You will find that most all "Pro" level lenses from Canon, Nikon, Tokina, Tamron and Sigma all have similar resolving power. What difference there is in sharpness between these usually is insignificant.
    As a former photojournalist I would opt for the Canon because of the beating your equipment takes from shooting everyday in all types of environments. But then again, when I was working the company supplied most of the equipment.
    If you're buying the equipment yourself ... and working on a portfolio (string book), get the Sigmas. They will focus just a tad slower than the Canons (may make a very slight difference for sports and fast action shots ... but probably not significant) and you probably won't be in real tough situations where the higher build quality of a Canon L is important. If you are using an APS-C sized sensor, don't get the 24-70, on a APS-C it's an odd range. I usually shoot at one end of the zoom or the other ... so I'd use the 10-22 for the wide stuff and the 70-200 for the longer shots ... these lenses covered both ends of the 24-70 and gave me more range. Now that I have a FF camera ... the 24-70 is no longer dusty.
    Gary
  3. Big Mike
    Dec 16, 2003
    33,854
    1,818
    Edmonton
    I would agree with that. The Canon is slightly better but it's also built tougher. However, the value of the two sigmas is pretty good, so you could really stretch your dollars.
  4. danpclements
    Apr 13, 2007
    19
    Littleton, Co
    Anyone else? Should this be moved to Photojournalism section?
  5. Big Mike
    Dec 16, 2003
    33,854
    1,818
    Edmonton
    This is right section to ask the question...but it's not really a question that other people can answer for you. A good photojournalist will use a lens that is appropriate to the task at hand. Also, the lens that is best for you, depends on your style of shooting.
  6. EOS_JD
    EOS_JD TPF Noob!
    Feb 15, 2007
    1,698
    One thing to considert is that the Canon lenses are weather resistant. If using a weather resistant camera, it makes sense to buy the better Canon lenses. The Sigma 24-70 f2.8 is a good lens for the money, as is the Sigma 70-200 f2.8
  7. JIP
    JIP No longer a newbie, moving up!
    Aug 29, 2006
    3,019
    Pittsburgh PA
    I am always a proponent of sticking with branded lenses so I would stick with the Canon but realize you will find out very soon that you absouloutley need the 70-200 and the 24-70. A suggestion I might make is to use a kit wide-angle lens if you have one to start out and get a fast 70-200 Canon and get the fast wide later.
  8. danpclements
    Apr 13, 2007
    19
    Littleton, Co
    Will it be fine to take portraits with at 70-200? My friend's family wants me to shoot their son's senior picture, and I believe that this lens will work fine, but not sure if I should go wider? if not, i'll be getting the 70-200 and 50 f/1.8 until i can afford the 24-70 2.8L. I have a kit lens, 35-80mm f/4-5.6 and 75-300mm f/4-5.6
  9. Mike_E
    Jan 26, 2007
    5,327
    266
    Put him under a tree and back up. :)
    The 50mm f1.8 will do practically everything you need for portraits if you don't mind moving around a little. (you'll need wider for groups)
    mike
  10. EOS_JD
    EOS_JD TPF Noob!
    Feb 15, 2007
    1,698
    Another option is the Tamron 28-75 f2.8. Fantastic lens for the price. Sharp and fast zoom. Almost as good as the L and a lot cheaper.
  11. fmw
    fmw No longer a newbie, moving up!
    Sep 30, 2006
    3,343
    397
    I know people won't consider this helpful but I don't understand why people want to buy equipment without knowing why they want it and what they will do with it. If your photography is lacking something that a new lens will address, then you should know what is lacking and how the lens will address it. In other words it might make sense to use what you have and gain experience so that you will one day know what it lacking and how a lens might address it. I have many lenses. Each one has a purpose and was purchased with that purpose in mind. I don't think there is another good way to do it. Sorry, I know this isn't helpful in an immediate sense but I think it is worth considering.
  12. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    well said and I do agree.
    However, there are people who realise they have some money left over and want to play. so they wonder if a new lens could add some fun. I think this is legitimate as you might explore new ways in photography which you do not "need", but which are opened up for you by the purchase of a new lens.
    but then I would really go for "play" lenses, like makro, or ultra wide angle, or fisheye,...
