Sigma 105mm macro for portraits?
Discussion in 'Photography Equipment & Products' started by Johnboy2978, Mar 15, 2007.
  1. Johnboy2978
    Johnboy2978 No longer a newbie, moving up!
    Oct 21, 2004
    1,797
    30
    Southwest Virginia
  2. StreetShark
    StreetShark TPF Noob!
    Mar 11, 2007
    219
    I heard the best thing to use for portraits is something close to a 70mm f/2.8 prime
  3. RMThompson
    RMThompson the TPF moderators rock my world!
    Nov 12, 2006
    1,888
    11
    I've had this same conversation with someone recently. Apparently the point of most non-distortion at a "portrait" is 105 - 110mm... so therefore a 70mm lens for digital is what you want.
    However I've personally seen a LOT of people using the 50mm 1.8 lenses for portraits becauce they are cheap and fast.
  4. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    I don't know if there really is a specific focal length that is best for portraits. The important point is that longer focal lengths will 'compress' the subject which is usually more flattering for portraits. The opposite if course is that wide angle lenses tend to accentuate the distance between things which isn't so good for portraits.
    100mm gets recommended, I think, because if you start to get too much longer, it becomes less practical for portraits. I'm sure portraits would look good from a 600mm F4 lens...but you would have to be like 50 meters from your subject...and the lens would be really heavy.
    To make a long story short, I'm sure the Sigma 105mm is a good portrait lens.
  5. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    The two most common portrait lenses are 85 and 135. Anywhere in between there is fine.
  6. EOS_JD
    EOS_JD TPF Noob!
    Feb 15, 2007
    1,698
    It might be a bit too sharp!! :)
  7. fmw
    fmw No longer a newbie, moving up!
    Sep 30, 2006
    3,656
    471
    It's actually the other way around. Macro lenses are designed with a flat field to be used up close. When you back up with them, the flat field is actually a slight detriment to sharpness. Don't misunderstand, it will be plenty sharp, but just a touch softer than a similar design without a flat field and not quite as sharp as it is up close.
    Incidentally, while I've done very, very little portraiture in my life, I have often used the equivalent of a 300mm lens on a 35mm camera. Of course, I've done some with wide angles too. You get the flattering perspective by backing away from the subject. Then you use a longer lens to fill the frame. How long a lens depends on how far back you are and how much of the subject needs to fill the frame. On a digital, I would think anything from 30mm for full figure up to 200mm for a head shot would be fine. As mentioned above, there aren't any rules.
  8. Johnboy2978
    Oct 21, 2004
    1,797
    30
    Southwest Virginia
    would 105mm be too long on a dslr sensor? Effectively it would crop as a 158mm on my pentax. Would I be better off going w/ a 70mm macro? I would really like the functionality of both the macro capability and something I could use for portraits. Thanks
  9. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    It's only too long if you can't back up. So if you are shooting in tight locations, then it may be too long. It also depends on the size of your subject...are you shooting head shots or full body shots? etc.
  10. xfloggingkylex
    xfloggingkylex TPF Noob!
    May 5, 2006
    1,292
    Frederick, MD
105 macro portrait
portrait photography 105mm macro
shooting portrait sigma 105mm macro
sigma 105 macro portrait
sigma 105 mm portrait
sigma 105 portrait
sigma 105 portrait shooting
sigma 105mm for portraits
sigma 105mm portrait
sigma 105mm portrature
