Sigma 70-300mm f/4-5.6 APO DG Macro
Discussion in 'Photography Equipment & Products' started by BubblePixel, Jun 15, 2006.
  1. BubblePixel
    BubblePixel TPF Noob!
    Nov 29, 2005
    148
    Canada
    Finally I'm getting this lens! It will be my first to go on my D50.
    I'm getting it as a BD gift! :mrgreen:
    Anyone here has it? and how do you like it? Honestly!:wink:
    Thanks!
  2. BubblePixel
    Nov 29, 2005
    148
    Canada
    up! :thumbup: ;)
  3. Mitica100
    Mitica100 Moderator Staff Member Supporting Member
    Nov 11, 2003
    9,778
    50
    Ahwatukee, AZ
    I have a Sigma 70-300 APO for a film camera (Pentax AF mount) and I love it! Sharp as a tack.
  4. BubblePixel
    Nov 29, 2005
    148
    Canada
    Thanks Mitica!
    I just realized mine is not APO just DG...:confused:
    Does that make a difference?
  5. PlasticSpanner
    PlasticSpanner TPF Noob!
    May 1, 2005
    4,125
    51
    Cheshire, England
    I believe the APO means Apochromatic which is an extra pair of lenses which adjust the focus of each colour band so that all colours are in sharp focus.
    Since all colours travel at different wavelegnths they each focus slightly differently, creating a slight "glow" around the image (usually red/orange glows around blues/greens).
  6. BubblePixel
    Nov 29, 2005
    148
    Canada
    Oh.... bummer I don't have that...!!:(
    Thanks for your explanation Plastic!
  7. PlasticSpanner
    May 1, 2005
    4,125
    51
    Cheshire, England
    It's not such a big thing. It really only comes into noticeable effect under f11-f8. Smaller apertures have a longer DOF allowing non Apo lenses to get a better overall focus on all colours.
    It's the exact same principle that makes a prism split white light into it's component colours.
  8. Mitica100
    Nov 11, 2003
    9,778
    50
    Ahwatukee, AZ
    Definition of apochromat from Wikipedia:
    An apochromat, or apo lens, is a photographic or other lens that has better color correction than the much more common achromat lenses. Chromatic aberration is the phenomenon of different colors focusing at different distances from a lens. In photography, it produces soft overall images, and color fringing at high-contrast edges, like an edge between black and white. Astronomers face similar problems, particularly with telescopes that use lenses rather than mirrors. Achromatic lenses are corrected to bring two wavelengths (typically red and blue) into focus in the same plane. Apochromatic lenses are designed to bring three wavelengths (typically red, green, and blue) into focus in the same plane. The residual color error (secondary spectrum) can be up to an order of magnitude less than for an achromatic lens of equivalent aperture and focal length. Apochromats are also corrected for spherical aberration at two wavelengths, rather than one as in an achromat.
    My Sigma has, I believe, only the front and the rear cell color corrected. It's very sharp indeed. Is it sharper than a non-apochromatic lens? Yes, it's noticeably sharper, but it's also more expensive. It is really up to the photographer to decide whether it's worth spending the extra $$ on color correction. Just my thoughts...
  9. LWW
    LWW No longer a newbie, moving up!
    Aug 3, 2005
    1,224
    7
    Dayton,Ohio
    http://www.sigmaphoto.com/lenses/lenses_all.asp
    If you go to the above link you will find that the 70-300 APO has 3 SLD (Sigma's verbiage for APO) elements while the other 70-300 has only 1 APO element.
    I was shocked when I read the post because I didn't think anyone was still making a 300MM lens without any APO glass. APO becomes critical beyond 200MM in film and in digital your 300MM becomes a 450MM equivalent and I suspected you were going to get junk.
    Now that we see that it DOES have an APO element I don't think you will have an issue. I suspect that with 3 elements it would be just a tad sharper, all other things being equal, but would probably require an enlargement of 11X14 or 13X19 to be noticeable...and then minimally so.
    I hope this helps.
    LWW
  10. BubblePixel
    Nov 29, 2005
    148
    Canada
    Thanks everyone for your input!
    Actually, I'm a bit dissapointed in the seller... I am a newbie and I usually ask alot of questions and I'm quite surprised he didn't mention this... I guess he thought I wouldn't notice...
    I think I'm drop by the store this week, to ask... more questions! hehehe!!
    Thanks again! Really appreciate it! :heart:
  11. AluminumStudios
    AluminumStudios TPF Noob!
    Oct 20, 2005
    99
    Pennsylvania
    I'm looking at getting this lens too (non apo version due to buget.) Does anyone know if it's infrared compatible? Some lenses give a bright spot (aka hot-spot) in the middle of IR photos.
    If anyone knows about this please let me know!
    Thanks,
  12. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    I almost bought the Sigma 70-300mm lens, and thank God I didn't!
    http://www.bhphotovideo.com/bnh/controller/home?O=productlist&A=details&Q=&sku=403209&is=DEMO&addedTroughType=search
    I saw a used one in a local camera shop while I was buying film, and since I only had my 35-70mm AF-D at the time, I was considering a telephoto lens because I desperately needed one.
    I was shooting earlier so my camera was already with me, and I decided to take a look through it.
    First off, there is no way with its max aperture that I would be able to handhold it at 300mm without using ISO 400 film (in broad daylight). Because it’s a compact, the f/stop changes throughout the zoom, which really blows because if your indoors, shooting even with ISO 400 film, you’d be lucky to get a shutter speed of 1/500 or 1/250 at 300mm and f/5.6. IMO, that’s flat-out unacceptable.
    The build quality of it just isn’t’ there either. Its all plastic and weighs maybe ┬╝lbs. that might be a plus for some, but it tells me that its cheap.
    I loaded up some film in my FE and took some snaps with it outside using my tripod (which was needed at 300mm). I wasn’t impressed, the images were nice and sharp at 70-150mm, but from 150-300mm, it became softer as you increased the focal length.
    Personally, I’m really glad I didn’t buy it because it really isn’t that good of a lens. Instead, I bought an AF Nikkor 80-200mm f/2.8 AF-D which is absolutely amazing. It is worth every penny of the extra cost because it has more elements, isn’t made out of just plastic, and is above all, f/2.8! However, it’s a bazooka. It can get heavy after carrying it around for a long time and the tripod collar is too small.
    http://www.bhphotovideo.com/bnh/controller/home?O=productlist&A=details&Q=&sku=124669&is=GREY&addedTroughType=search
    I paid $935 for it with shipping, UV filter, and an HB-1 lens hood, but it seems B&H lowered the price since I bought mine.
    EDIT: Unless you're in broad daylight, there will be very few times when you'll be able to hand hold a camera at 300mm without VR, so looking at a 70-300mm lens IMO is a wasted effort becuase you'll never go beyond 200 or 210mm unless on a tripod. If you need to reach out to 300mm, consider 200-300mm, or 200-400mm lenses becuase you'll get awful results from a lense with a minimum focal length of 70mm going all the way out to 300mm especially with a compact lens.
sigma 70-300mm dg macro bdprice
sigma apo dg macro 70-300 price in bangladesh
