Simple film math help
Discussion in 'Beyond the Basics' started by CineMan, Jun 19, 2006.
  1. CineMan
    CineMan TPF Noob!
    Jun 19, 2006
    Ok back to math class. A guy leaves New York on a train headed west. He has a camera with ISO100 film loaded in it. He is so excited to be on a train he doesn't realize that his camera is set for 200 speed film until after he shoots it. When he goes to the processor he needs to ask to push or pull how much to compensate?
    :wink:
  2. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    Welcome to the forum.
    I believe that would be a push of one stop. If you are shooting negative print film...I might not even worry about it. It has a pretty decent latitude and one stop should not stress it too much.
  3. bigfatbadger
    bigfatbadger TPF Noob!
    Mar 19, 2006
    464
    Nottingham, UK
    Is it black and white? If so it's only one stop out so you might be able to get away with normal processing times, especiialy if you're printing yourself.
    If not, I think the rule of thumb is that you add two minutes to the exposure time, but there's probably more specfic information for your particualr film. What film is it?
  4. CineMan
    CineMan TPF Noob!
    Jun 19, 2006
    I did it intenionally on two rolls, because I was shooting in overcast Dublin, Ireland and thought exposure time would be too long for handheld if I set my camera to auto exposure at asa100.
    One is B&W the other is Color. B&W is AGFA APX 100. The color roll is, get this, Kodacolor II which expired in 1984.
    oh, and I am not printing or processing myself.
  5. bigfatbadger
    Mar 19, 2006
    464
    Nottingham, UK
    Apparently you can develop it in rodinal for 11 minutes, but like Big Mike says, it'll probably be alright. I'd just develop the Kodacolour, if it's got this far it'll put up with a bit more!
  6. CineMan
    CineMan TPF Noob!
    Jun 19, 2006
    The place that I go to only uses Kodak Xtol developer for BW processing. Is this ok? And how many stops does 11 minutes equate to?
    Is one step in film speed equal to one f-stop?
    Oh and the most important shots on that BW roll are concert footage shot with a flash in a dark club, about 3 meters from the stage.
  7. Torus34
    Torus34 No longer a newbie, moving up!
    Jan 26, 2006
    2,117
    37
    Tottenville, Staten Island, NYC USA
    The math:
    ASA/ISO film speeds in one-stop increments are 25, 50, 100 (125), 200, 400, 800, 1600, etc.
    If you're working in B&W, consider processing your own film. Also consider bulk loading.
  8. ThomThomsk
    ThomThomsk TPF Noob!
    Oct 27, 2005
    441
    50ยบ north
    Like Big Mike said, it's a push of one stop, but don't sweat about it - your shadows will be a little dense but there isn't much that can be done about that now. With the 1984 Kodacolor, the effective film speed is likely to be a lot lower than what it says on the box, depending on how it has been stored, but colour negative film is amazing stuff and you could still get something usable. Let us see the results, OK?
  9. Mr. Krinkle
    Mr. Krinkle TPF Noob!
    Jun 7, 2006
    29
    Lima, Peru
    i think you have to push your negavite 40% more than the basic time. i did it with kodax tri-x which developes in 10 minutes on D76, so i developed for about 14 minutes.
  10. Mr. Krinkle
    Jun 7, 2006
    29
    Lima, Peru
    so, it will be 40% more or less of time for each stop.
  11. mysteryscribe
    mysteryscribe TPF Noob!
    Feb 1, 2006
    6,071
    in the middle of north carolina
    one stop forget it (((((it's film)))))
    but under exposed is always push... over exposed is always pull.. A lab worth a darn if you tell them what you did they will know what to do...
