simple lens Q ?
Discussion in 'Photography Beginners' Forum' started by minister, Jul 21, 2010.
  1. minister
    minister TPF Noob!
    Jul 7, 2010
    192
    8
    Delhi
    Hi,
    as I am noob I have right to ask silly question
    hear I goes - I have 18-55 kit lens
    as far as i understand I can shoot 18mm wide shot and 55mm narrow shot
    my confusion is if I wanted to shoot a wide angel , why to buy those small focal length when I already have 18mm wide available ,
    and why those small number wide angel lens say 24mm so expensive because the aperture they provide, my best guess !!!
    my simple question is what would i achieve with those small focal length lens what i can't get with my 18-55 mm :meh:
  2. oldmacman
    oldmacman TPF Noob!
    Jul 16, 2010
    1,597
    70
    Southern Ontario
    If you are using an 18-55, I'm going to assume you have a crop sensor, APS-C, sized sensor. This means to determine your actual focal length, you multiply the number by its crop factor (1.6) for APS-C. So your 18mm end is really a 29mm, more or less.
    The same would go for the 24mm.
    Yes, the aperture is part of the reason the lens will be more expensive, but there are other factors like:
    - improved optics
    - build quality
    - flare control
    - sharpness
    Until you get really good at photography,or you need to make larger prints, your kit lens should serve you well.
  3. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    Because they are different. Different in build quality, optical quality as well as other performance factors.
    A lens usually cost more when ...
    - It is well build and solid. Some of them even have weather seal.
    - It has great optics so that the final image is sharp and less optical issue such as distortion or CA.
    - It has build in image stabilizer.
    - It has fast quiet autofocus motor.
    - It has a large max. aperture.
    So in your case, I believe the 24mm lens most likely is a faster lens (larger max. aperture), better build and optically better than your stock kit lens. And therefore cost more.
  4. rusty9
    rusty9 TPF Noob!
    Apr 13, 2009
    563
    Madison, MS
    well, it provides a larger aperture (which is more expensive) so it performs better in low light. the lenses you mentioned have better build quality, too. and those lenses have less zoom range. the more zoom it has the less quality. so that is why primes are better than zooms.
  5. rusty9
    rusty9 TPF Noob!
    Apr 13, 2009
    563
    Madison, MS
    dang it. you two beat me to it.
  6. TiCoyote
    TiCoyote TPF Noob!
    Apr 28, 2009
    624
    4
    New England
    All of those factors are correct (build quality, optics, aperture, etc.). Also, wide-angle lens is a bit of a different animal. The lens is round, so it wants to produce a round image. However, the sensor is rectangular, so the image needs to be focused in a way that's rectangular. Refocusing a round image in a rectangular format is tricky, and therefore expensive. If you just let the image focus so that it was round, you would have a distorted image. A fisheye lens allows it to focus a round image. Essentially, a fisheye is a wide angle lens that does not produce a rectangular image. You will notice there are quite a few inexpensive fisheye lenses for this reason (amongst others).
  7. Robin Usagani
    Robin Usagani Been spending a lot of time on here!
    Jun 6, 2010
    10,348
    2,175
    Denver, CO
    Minister, if you really want the "wide angle" feel on your camera, you have to by 10mm or 12mm because your sensor is cropped. The expensive fast wide angle lens are really meant for a full sensor. If you buy that expensive lens and use it on your camera, it will be a like a fast zoom lens.
  8. Dao
    Mar 24, 2008
    6,252
    418
    St. Louis
    :scratch:
  9. minister
    minister TPF Noob!
    Jul 7, 2010
    192
    8
    Delhi
    I had this Q also in my mind you just cleared
  10. minister
    minister TPF Noob!
    Jul 7, 2010
    192
    8
    Delhi
    I am very thankful you all are so help full to clear my doubts
  11. Robin Usagani
    Jun 6, 2010
    10,348
    2,175
    Denver, CO
    what? PUt a 24mm on a crop sensor, what will that do?
  12. Dao
    Mar 24, 2008
    6,252
    418
    St. Louis
    But it will not change into a zoom lens though.
