select the layer, then go to edit >transform> scale.
Could you also select the layer and use the grips to resize?
Grips are the little boxes that appear at the corners and in the middle of the sides, around the box that represents your selection. If you grab a corner grip, you can compress/expand the image in either direction and if you hold down the shift (or is it alt) key while doing it...it will lock the aspect ratio so you don't compress/skew the image but only resize.
