Slave Flash
Discussion in 'Photography Beginners' Forum' started by atseeyob, Mar 29, 2008.
  1. atseeyob
    atseeyob TPF Noob!
    Aug 22, 2007
    43
    Hello Friends,
    I need to use at least 2 slave flashes for a Studio type pictures I am about to take. Budget is tight. I would like to get some advice as to which flashes can I get for less than $75.00 each still produces decent power. I use Canon 30D and my main (Master) flash is Speedlight 580EX II.
  2. Village Idiot
    Mar 20, 2008
    7,274
    406
    The problem is, to use Canon's proprietary system, you're going to need a Canon flash and they're probably going to run about $200 each. You could always get something like a Sunpak 383 for $80 and pick up some optical slaves for cheap.
  3. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    Yup, just remember that when in E-TTL mode, a Canon flash will emit a pre-flash that may trigger optical slaves prematurely. To work around this, you could get optical triggers that can be set to ignore pre-flash, or you could use the Canon unit in manual mode.
