chorleyjeff
I need a film scanner and have the chance to get an Epson 4180 cheap. Has anyone any experience of using this scanner for film scanning with an opinion about the quality of scans at,say, 2400ppi ?
Thanks
Jeff
Thanks
Jeff
I totally agree with you. I might add here that the image resolution should better be scaled in a way that matches the printer's native resolution. For example, if the printer prints at 300dpi or 600dpi or 1200dpi, the 300dpi picture is fine. For a 360/720/1440dpi printer, I would scale the image at 360dpi for best results.Hair Bear said:Resolution at 300dpi is OK if you are printing at around 1:1 of the file size.
But if you want to enlarge files then you will be needing the extra 'real' res to do it.
FMW, you may not notice the extra because your output device can't show it. That doesn't mean you shouldn't scan at a larger res, it just means you have found 'your' best resluts v time to scan v file size.
If you intended to do larger prints you may need a higher resolution file.
