slide scanners
Discussion in 'Beyond the Basics' started by skatephoto, Feb 16, 2004.
  1. skatephoto
    skatephoto TPF Noob!
    Nov 14, 2003
    72
    Can anyone give me some advice on slide scanners. Just basically anything you can help me with. Will it save me money using that instead of having prints made at a lab.thanx
  2. marksw
    marksw TPF Noob!
    Nov 21, 2003
    9
    However, it takes a long time to scan slides - even on a super fast machine!
    I got a Minolta Dimage Scan Dual III which is OK (picks out the grain on my slides), but the process of scanning is tedious.
    You have to try and weigh it up:
    Pros for getting a scanner
    - full control over scans
    - scan when you want
    - can print as many as you want
    - control over cropping/composition
    Cons for getting a scanner
    - could be an expensive initial expense
    - takes lots of time to make scans
    - Cost of printing yourself (even if it is not a lot)
    Pros for getting prints made from slides
    - best quality
    - cheaper cost over a short time
    Cons for getting prints made from a slide
    - expensive over time
    - you have to wait for the print (but this makes it exciting doesn't it?)
    - no control over cropping and colour adjustment
    I'm sure there are more.
    The long and the shot of it is that it depends on the number of prints you want making, and the expected lifespan/usefulness of the scanner/printer.
    Only you can answer that question!
    I got a scanner so I could scan my old slides in as I plan to go fully digital one day. If I ever took a picture that I thought was great and wanted a print of, I'd still take it to the lab to get the best print possible!
    Hope this helps,
    Mark
  3. voodoocat
    voodoocat ))<>(( Supporting Member
    May 15, 2003
    5,277
    17
    Gilbert, AZ
    That's cause there is grain on the slide or negative. Full 2880 dpi scans of a ISO100 slide film shows almost no grain. 2880 dpi scans of ISO200 and up shows grain because you're enlarging the negative to over the size of an 8x12.
    Minolta is coming out with the Scan Dual IV for the same price as the III so look out for that. No other slide/negative scanner can touch it for the price. Even 11x14 prints look beautiful.
  4. voodoocat
    May 15, 2003
    5,277
    17
    Gilbert, AZ
    Oh and it's not really that time consuming to get good scans once you have had a bit of practice. And really if you expose your slides and negatives right the less work you have to do when scanning. I recommend using Vuescan instead of the standard software. Every negative has it's own shade of amber which will in turn create a green-blue color cast. Good scanning software helps with that considerably.
  5. marksw
    marksw TPF Noob!
    Nov 21, 2003
    9
    It was a good thing that it picks out the grain :lol: - means the scan resolution is good enough!
    Where do you get 'Vuescan' from? It may be worth a try...
  6. voodoocat
    May 15, 2003
    5,277
    17
    Gilbert, AZ
    Vuescan from Hamrick Software. http://www.hamrick.com/ they have a free trial. But some of the better slide/negative tools are on the full version.
  7. marksw
    marksw TPF Noob!
    Nov 21, 2003
    9
    Thanks. For $79.95 it better be good! I'll give the free version a try :)
