slowest acceptable portrait lens?
Discussion in 'Beyond the Basics' started by Osmer_Toby, Jun 2, 2004.
  1. Osmer_Toby
    Osmer_Toby TPF Noob!
    Jun 4, 2003
    1,768
    5
  2. markc
    markc TPF Noob!
    Mar 8, 2004
    4,237
    6
    Rochester, NY Velocity: Unknown
    I think it really depends on the look you are going for. It doesn't give you much choice as far as DOF goes, so it wouldn't work well for the style I like to use. Since I have some fast primes, I'd be happy to own one when I wanted more reach, but I don't think I would use it for portraits often.
  3. voodoocat
    voodoocat ))<>(( Supporting Member
    May 15, 2003
    5,277
    17
    Gilbert, AZ
    I wouldn't really consider f4.0 to be fast enough for a portrait lens. I'm not sure what the contrast and sharpness is like on that lens, so that is another thing to consider.
    The 85mm 1.8 lens is a wonderful portrait lens.
  4. Harpper
    Harpper TPF Noob!
    Feb 4, 2004
    810
    USA
    I also wouldn't consider that fast enough to be a good portrait lense. F4.0 doesn't give a shallow enough DOF for my liking. You also have to remember that most lenses are sharpest at their sweet spots. When you get more to the ends of the lense range the sharpest starts to drop off.
    I've been told that a good rule of thumb is to stay 1-2 stops above or below your max range. So for f4.0 you'll probably want to shoot at f4.5 which will make it even slower. It's something to keep in mind when buying lenses. For example, if you want to shot at f2.0 then get a f1.8 lense or faster.
    I consider anything slower than f4.0 as more of a landscape lense where you'll want more DOF so that you'll have everything in focus.
  5. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    I think it depends a lot on what kind of portrait you are taking. The DOF of f/4 will be pretty shallow if you are out past 150mm. When I'm shooting landscapes or similar subject matter, or when I'm printing in the darkroom, I always try to stop down at least 2 stops more than wide open to get maximum sharpness, but with portraits, I usually don't worry about it. With any decent lens the images will still be very sharp.
    That said, I guess I don't really think of a 75-300mm lens as a portrait lens. I usually stick to fast primes for portraits, and think of zooms as more all around lenses. So if you want a good, all around lens that will also do portraits, then get it. If you very specifically want a portrait lens then I'd say get an 85mm to 135mm prime lens (for 35mm film).
  6. Osmer_Toby
    Jun 4, 2003
    1,768
    5
    is the 85mm long enough to avoid distortion?
  7. voodoocat
    May 15, 2003
    5,277
    17
    Gilbert, AZ
    I think I heard 75mm + will provide distortion free frame filling portraits. I'm not sure what the barrel distortion specs are on the 85mm vs the zoom you're looking at... but I'm sure the 85mm is better.
    I'm saving up to buy the 85mm 1.4 lens someday. Sure it's 3 times the price of the 1.8 but the bokeh is so damn perty :D
  8. Harpper
    Harpper TPF Noob!
    Feb 4, 2004
    810
    USA
    Just wanted to make a correction in my last post. I was refering more to the bokeh as opposed to shallow DOF. I love the bokeh from my 50mm 1.4, which I can't get from my 28-200mm.
    Voodo's post jogged my memory to the correct wording. ;)
