SO CONFUSED!
Discussion in 'Photography Beginners' Forum' started by love.sublime, Jan 31, 2008.
  1. love.sublime
    love.sublime TPF Noob!
    Jan 30, 2008
    How does the Sunny 16 rule work??
  2. Antithesis
    Antithesis No longer a newbie, moving up!
    Aug 24, 2007
    1,340
    16
    Caribbean
    I can't really remember the shutter speed because I've never actually had to put this to use, but I think it means in direct sunlight, stop down to f/16 and use a shutter speed of 1/125th.
  3. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    in bright sun...use f/16 and the reciprocal of your shutter speed.
    AKA for ISO 100 use 1/100 (probably closer to 1/125)
    Try it out...it works quite well.
  4. Antithesis
    Aug 24, 2007
    1,340
    16
    Caribbean
    Good call, forgot the ISO part.
  5. MarcusM
    MarcusM TPF Noob!
    Sep 12, 2007
    1,236
    St. Paul, MN, USA
    Yup...sideburns said it well...although did you mean "reciprocal of your film speed/ISO?"
    I just read it in the book I'm reading - "Photographing Plants and Flowers" by Paul Harcourt Davies
  6. ThomThomsk
    ThomThomsk TPF Noob!
    Oct 27, 2005
    441
    50ยบ north
    If you are interested in 'rule of thumb' exposure, also take a look at Fred Parker's Ultimate Exposure Computer:
    http://www.fredparker.com/ultexp1.htm
    Scroll down to the table headed Exposure Value Chart, which gives you the EV number for lots of different lighting situations. Scroll further down to the next chart, find that EV number for your ISO setting on the left and look up the aperture and shutter speed settings on the right.
  7. love.sublime
    Jan 30, 2008
    right on!
    thanks
  8. Mystwalker
    Mystwalker TPF Noob!
    Jan 25, 2008
    544
    WOW!!
    Thanks much.
    That is exactly what I needed. :thumbup:
  9. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    Hell's Kitchen, New York
    Just be a bit careful with Fred Parker's use of 'EV' - it can be a bit confusing because it isn't consistent with established practice. He uses it in place of BV, or brightness value. EV is not a measure of scene brightness, it is simply a combination of shutter speed and aperture; or of brightness and sensitivity (ISO). When he quotes EV, he means EV at ISO 100 only, not at any other ISO. The EV will be different for other ISOs in the same scene brightness.
    It would have been a lot simpler if he had stuck to the method given in the document his table is based on, ie using BV for scene brightness.
    Best,
    Helen
