Soft Images from Canon 5d
Discussion in 'Photography Equipment & Products' started by kaushal, May 18, 2007.
  1. kaushal
    kaushal TPF Noob!
    May 18, 2007
    6
    Hi, I am new to this forum...actually this is the first time i have entered a forum although I have been an avid reader of this forum and have received valuable info from all participants over the years.
    I recently purchased a new Canon 5d and 17-40 lens after hearing of the crisp images possible with this camera (in addition to the wonderful FF). Anyway when i downloaded my images I found them to be slightly soft. So i exchanged the lens but the results were still not as sharp as i expected.
    I shot in single focus point, single shot and at a high enough shutter speed so as to cause no camera shake. The photographs were of historic buildings about 50 metres away.
    Was wondering if it could be my camera that is the problem. Is there any fool proof way to confirm this? Because I may be able to convince the seller to change the camera this time but Im sure beyond that he is gonna start getting a little annoyed and i will then have to send my stuff to canon which is time consuming and results in lost shooting time:-(
    Would love to upload an image but am not sure how to...
  2. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Welcome to the forum.
    Read THIS link to find out how to post your images.
    Seeing the images should help to diagnose the problem. Are all your images soft? Or just these ones of buildings 50m away?
    What format are you shooting in, JPEG or RAW? Are you applying any sharpening? (most digital images do require a bit of sharpening to reach their full potential). How close are you zooming in to the images when you inspect them?
  3. GreenSlime89
    GreenSlime89 TPF Noob!
    Dec 13, 2006
    96
    Scotland
    I'm not sure how to see what the fault is, but I can tell you how to upload it. First, go to http://www.imageshack.us and upload the image, by clicking "Browse" and find the image you want to upload, select it, and click "Open" Then click "Host it!" When the next page loads, highlight the code with the text "Thumbnail for forums (1)" beside it. Then paste the code into the post and that should be you.
    I'm surprised that a 5D should have soft photos, I've got an old 20D from my friend who sold me it after he upgraded, he's had no trouble like this...
    EDIT: It seems I was slow with my typing... Disregard this post, I'm terrible at explaining.
  4. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    generally speaking: the more expensive the camera, the softer the images you get straight out of it ;)
    If you had a 1Ds Mark II you would probably also think it produces soft images. Why is this ? well, images generated from bayer pattern sensors are soft by definition since each pixel only sees one colour and then an interpolation scheme is applied. sharp images you only get after sharpening. point and shoot cameras usually do alot of sharpening in-camera, whereas higher end dSLRs do less by default. RAW iamges most of the time are even not sharpened at all. By doing less in-camera sharpening, the photographer gets more control over the final image, but also needs to do more postprocessing of course.
    You can change the degree of in camera sharpening, by either changeing the mode you shoot it, what is your 5D set to? also you can adjust it manually and customise modes.
    do you shoot raw or jpg?
    Also, if you shoot with the aperture wide open, you will get softer images, in particular towards the edges of the frame, and in particular in wide angle on full frame cameras.
    best if you send some examples, and try varying apertures and focal lengths.
  5. ericande
    ericande TPF Noob!
    Oct 23, 2006
    136
    Seattle
    What aperture are you shooting at?
    if you shoot at f/22 any lens will be a little bit soft and if you shoot wide open most will be somewhat soft or at least softer then they could be. I'm guessing that lens is sharpest somewhere around f/8.
    But as others said, when you post up your photo it will help a lot.
  6. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    oh, and I forgot, in the worst case it could also be that either your camera or the lens AF is not adjusted well.
  7. kaushal
    kaushal TPF Noob!
    May 18, 2007
    6
    Wow guys. This is amazing. I already got so much information...thanks!
    I have tried to upload an image which was taken from less than 50m away and at night. I used a steady tripod and mirror lock (with self timer) and an aperture of f11. I thought the pic would be tack sharp but was disappointed. Here is the url:
    [​IMG]
    hope my image is there.
  8. kaushal
    kaushal TPF Noob!
    May 18, 2007
    6
    Oh and i shot it in RAW and sharpened the image in unsharp mask (about 140, 1.2, 0)
  9. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    this is not too sharp indeed. but then again it is downscaled in size.
    it is also certainly grainy (high iso?)
    maybe we should start with daylight shots at ISO 100
    are you sure the tripod was very steady? or maybe the ground was shaking (cars, ...)
  10. kaushal
    kaushal TPF Noob!
    May 18, 2007
    6
    Hi Alex
    You are right...the pic was shot at ISO 640 so it is grainy. It was a 5 sec exposure so could have neen vibration from the cars/buses (although i believe my tripod is pretty stable).
    Here is another test pic i took at 1/160, f4 at ISO 100...this is from a much closer distance:
    [​IMG]
    I am also gonna borrow a friends 100mm macro lens tomorrow and take some pics with that. If those images are not clear then i suppose i can assume that my camera is at fault...
    I guess I am just hoping that my camera is ok since it will be much easier for me to exchange my lens.
  11. kaushal
    kaushal TPF Noob!
    May 18, 2007
    6
    Saw your website Alex. Wonderful images! That was exactly the quality I hoped to acheive when I upgraded from my Nikon D80 to the Canon 5d.
  12. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    Well, most on that site is scanned slide film :p
    The rest is shot with a Canon 5D though.
