SOFTBOX QUESTIONS
Discussion in 'Beyond the Basics' started by itsarvin2, Mar 15, 2010.
  1. itsarvin2
    itsarvin2 TPF Noob!
    Mar 8, 2010
    18
    Los Angeles
    Im planning to get a softbox. I need some help on some proper ways of using it. It will be used mainly on outside shoots. I guess my main question is how would i set it up for example ISO, shutter speed aperture, White balance etc.
    sorry guys its such a noob qurstion
  2. LBPhotog
    LBPhotog TPF Noob!
    Mar 3, 2010
    382
    New Hampshire
    A softbox doesn't really change your ISO setting or your white balance ...
    Basically you put the softbox over your flash and you'll probably want to set your FLASH COMPENSATION to +1 or +2 (depending on the softbox) and use it that way (these instructions are for a camera flash) ....
    For a more thorough instruction are you using this on a strobe or a flash ... just kinda wondering a bit more info.
  3. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    A soft box is just a light modifier. We need to know about the light itself, in order to help you.
  4. itsarvin2
    itsarvin2 TPF Noob!
    Mar 8, 2010
    18
    Los Angeles
    It will be going on a strobe.
  5. itsarvin2
    itsarvin2 TPF Noob!
    Mar 8, 2010
    18
    Los Angeles
    will be a night shoot
    im using a alienbee strobe
  6. LBPhotog
    LBPhotog TPF Noob!
    Mar 3, 2010
    382
    New Hampshire
    Ok, I use ABs too ... so you just toss the softbox on your AB - easiest thing that you can do is get a flash meter to meter your flash out put an shoot away.
  7. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    OK, now we are getting somewhere.
    First thing is that the camera should be in Manual mode.
    The exposure from the strobe is controlled by the aperture setting and the power setting on the strobe. The shutter speed has no bearing on the flash exposure, just remember to keep it longer than your camera's max sync speed. The shutter speed can be used to control the ambient exposure though.
    So if you use a fast shutter speed, 1/200 for example, your ambient (background) is likely going to be very dark. But if you use a long/slow shutter speed, then you can get more ambient exposure.
    The aperture & ISO will affect both the ambient and flash exposures.
    Lastly, the distance from the light to the subject, will also affect the exposure from the strobe.
    A flash meter is the right tool for measuring the flash output, it would tell you what aperture you need to use for the shot. If you don't have a flash meter, then you should be able to get there by guessing & testing.
  8. eric-holmes
    eric-holmes No longer a newbie, moving up!
    Aug 8, 2009
    1,858
    49
    Arkansas
    What is a good size softbox for 1 person shoots mostly done from the waist up in an outside enviroment.
  9. webmaster705
    webmaster705 TPF Noob!
    Feb 19, 2010
    70
    Pakistan
    thats right , its just light modifire you just need to know your requirements throughly and your circumstances, then fix it according to your needs
  10. sxr
    sxr TPF Noob!
    Jul 3, 2008
    35
    Phoenix, AZ
    Not questioning your knowledge or trying to pick on you, but seriously, if you ask a question like this you shouldn't be anywhere near strobes! Start off with speed lights and work your way up. Once you understand the basics of photography, move forward.
  11. KmH
    Apr 9, 2009
    40,750
    5,588
    Iowa
    Go ahead and start with whatever lights you have available to use. :thumbup:
    You can learn the basics as you go.
  12. Andrew Boyd
    Andrew Boyd TPF Noob!
    Jun 9, 2009
    81
    New Orleans, Louisiana
    The first softbox to buy would be about 3ft x 4 ft. This is a great size that will handle almost anything you need, and the best one to start with. You can set it up on a regular 8 ft. light stand and be ok. Outside, you'll want to weight down the bottom of that stand to keep it from blowing over!
    I have a Chimera box that's still going strong after 20 years (amazing). There are lots of good brands out there now as well. Westcott makes some decent, cheaper ones you might look at too. DON'T FORGET: You'll need to buy the proper speed ring to fit your brand of strobe. This can be a big additional expense.
    Good luck!
    Andrew'
    The Discerning Photographer
