Software for batch edge finding
Discussion in 'Graphics Programs and Photo Gallery' started by jvgig, Mar 19, 2008.
  1. jvgig
    jvgig TPF Noob!
    Sep 26, 2007
    326
    I am currently scanning in all of my film shots, but since I have several 1000 to scan, I either have to do it myself or watch my picture quality deteriorate. My scanner can determine the boundaries of pictures, but whatever software it uses takes an incredibly long time. To scan one roll of film takes about an hour to an hour and a half during which time I cannot leave my computer...An impossible task. However, if I let the scanner software just scan, I can do a roll in about 5-10min, but the 4 images are on one superfile. So, what I need is a program that I can tell to go through a few hundred of these images and pick out the pictures from the white background and save them as individual files. I do not have the time to do this manually. I don't care if it even takes 15 hours to do, I just don't want to have to babysit it.
    Is there software that does this?
    btw, I am scanning 4x6s at 600dpi and 24bit color (seems to be the best picture quality with a reasonable scan time)
    Thanks
  2. dkf10425
    dkf10425 TPF Noob!
    Oct 3, 2007
    91
    Columbia, Md.
    The only thing I can think of is to create an action set using the "crop and straighten photos" feature in photoshop, then run the "automate-batch" command on the folder with the photos. You will have to save each photo after the automate command has run, but it should crop the whole folder of photos.
  3. jvgig
    jvgig TPF Noob!
    Sep 26, 2007
    326
    So, could I then just select a folder of a hundred of these files and have it run on those, and then save the files, or do I have to save after each one before it moves on to the next?
  4. dkf10425
    dkf10425 TPF Noob!
    Oct 3, 2007
    91
    Columbia, Md.
    You don't have to save each one before it goes to the next. It will batch process the entire folder. Because this is a resource heavy action set, I would go to preferences in photoshop and under "performance" temporarily bump up the amount of ram allocated to photoshop.
  5. MountainPaul
    MountainPaul TPF Noob!
    Feb 14, 2007
    30
    The lazy way of doing it is to use a script.
    Here is one that I wrote for Photoshop CS2/CS3
    save the code as FileName.jsx
    Then from Photoshop File - Scripts - Browse (to where you have saved it)
    It will process all JPG,TIF and PSD files in the selected Folder
    The output files will be placed into a folder called Edited off the selected folder.
    Hope its off use to you.
    Paul.
    #target Photoshop
    app.bringToFront;
    var inFolder = Folder.selectDialog("Please select folder to process");
    var fileList = inFolder.getFiles(/\.(jpg|tif||psd|)$/i);
    var outfolder = new Folder(decodeURI(inFolder) + "/Edited");
    if (outfolder.exists == false) outfolder.create();
    for(var a = 0 ;a < fileList.length; a++){
    if(fileList[a] instanceof File){
    var doc= open(fileList[a]);
    doc.flatten();
    var docname = fileList[a].name.slice(0,-4);
    CropStraighten();
    doc.close(SaveOptions.DONOTSAVECHANGES);
    var count = 1;
    while(app.documents.length){
    var saveFile = new File(decodeURI(outfolder) + "/" + docname +"#"+ zeroPad(count,3) + ".tif");
    SaveTIFF(saveFile);
    activeDocument.close(SaveOptions.DONOTSAVECHANGES);
    count++;
    function CropStraighten() {
    function cTID(s) { return app.charIDToTypeID(s); };
    function sTID(s) { return app.stringIDToTypeID(s); };
    executeAction( sTID('CropPhotosAuto0001'), undefined, DialogModes.NO );
    function SaveTIFF(saveFile){
    tiffSaveOptions = new TiffSaveOptions();
    tiffSaveOptions.embedColorProfile = true;
    tiffSaveOptions.alphaChannels = true;
    tiffSaveOptions.imageCompression = TIFFEncoding.TIFFLZW;
    activeDocument.saveAs(saveFile, tiffSaveOptions, false, Extension.LOWERCASE);
    function zeroPad(n, s) {
    n = n.toString();
    while (n.length < s) n = '0' + n;
    return n;
  6. jvgig
    jvgig TPF Noob!
    Sep 26, 2007
    326
    Since I do not currently own Photoshop, is there a less expensive program to do the same thing? Does Elements have this feature?
  7. MountainPaul
    Feb 14, 2007
    30
    If/when you have all your pictures scanned you could then download a trial version of Photoshop from
    http://www.adobe.com/downloads/
    At least you would get all the hard work done for you and FREE.
    Paul.
automate crop and straighten photos
crop and straighten photos batch
cropandstraightenbatch.jsx
cropphotosauto0001
digital photo edge finding
edge finding graphic software
image edge finding software
photoshop elements jsx
program for finding image edge
straighten.jsx
