Some Diffuser Help.
Discussion in 'Beyond the Basics' started by feRRari4756, Feb 18, 2009.
  1. feRRari4756
    feRRari4756 TPF Noob!
    Dec 25, 2008
    323
    Hey guys I use a difuser on my 30d pop up flash.
    Would I get the same effect if I used a diffuser and flash compensastion to 0
    as
    if i used no diffuser and set my flash compensation to like -1 or -2?
  2. Jaszek
    Jaszek No longer a newbie, moving up!
    Oct 7, 2008
    2,177
    31
    Brooklyn, NY
    no. As the name says a diffuser diffuses the light and the flash compensation decreases the power of the flash. Correct me if I'm wrong.
  3. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Light has certain properties, two of which are intensity and 'quality'. Intensity is controlled by the FEC...if you turn it up, it gives you more light...it's more intense. If you turn it down, it's less intense.
    The quality refers to it's softness on the subject. This is controlled by the size of the source and the distance to the subject. A diffuser should increase the size of the light source, thus making it softer.
    A diffuser will also eat some of the light...but because your flash uses E-TTL auto flash metering, the camera will just tell the flash to use more power to make up for the loss from the diffuser. So you may want to do both....use the diffuser and turn the compensation up or down.
    Also, the E-TTL system relies on the reflection of the preflash to determine it's power. So if you are shooting a subject dressed in white, you will get different results than if you are shooting a subject dressed in black etc. Don't be afraid to adjust your FEC as needed.
    My suggestion is to glue the built-in flash down and never use it ;)
    Get a flash that can tilt & swivel, so that you can use bounce flash.
