Hi Jennifer,
Some nice captures here.
A few look a little cold, soft and 'drained out' tho.
It says your images are ok to edit, so i did a quick edit for you.
Here is what i did in Photoshop:
- Open levels, add a bit more contrast
- Open curves, brighten image (slightly underexposed) push the highlight end up
- Open Hue/Saturation: this is quite an important one for a quick fix. In overcast days or shooting through glass, the first thing to go off is colour balance, as you can see here its rather cold, and there is always going to be too much cyan and blue in the whites, so to fix:
Select Cyan from the drop down menu, reduce it by 80%. Then select blue from the drop down menu, reduce by 70%
I then added some more yellow and touch of red to add more warmth and restore the colour in the Tigers coat.
- Flatten layer, duplicate, on one use smart sharpen, just enough to remove the softness, then added a layer mask to remove the effects from the whiskers... i find using sharpening on definate bold lines like whiskers can look over sharpened.
Done!
