pasteofanchovie
- Joined
- Jul 21, 2008
- Messages
- 28
- Reaction score
- 0
- Location
- St. Louis Area, MO
- Can others edit my Photos
- Photos NOT OK to edit
Sorry I don't have any critique, just a question
How do you get that effect on the pictures with the water, where it kinda gives it that "brushed" look? Sorry if thats a bad way to describe it.
Is that a filter as in a lens filter, or is it something you select in the options menu?
The ND filter is being used as a way to lower the light coming into the camera to make the shooter able to use a slower shutter speed. Bottom line is a slower shutter speed will make the current and moving areas of the water blur to get the "brushed" look. Of course when you do this it will be necesarry to use a tripod.Is that a filter as in a lens filter, or is it something you select in the options menu?
the G9's "built in ND filter" is nothing more then just the lens being stopped down.
They are some nice shots, however they skies look overexposed and some of the highlights blown out.
It's quite difficult. You can either set & lock the exposure for the sky, then in PP use a "D-lighting" (or the equivalent) to brighten the shadows, or you could take 2-3 photos and create an HDR image with them. Or, possibly, you can use a circular polarizing filter to darken the sky, which will hopefully turn it into a blue.What is some good advice for keeping the sky from being overexposed and having blown out highlights?
