someone tell me about Cokin filter system
Discussion in 'Beyond the Basics' started by bean, Apr 26, 2004.
  1. bean
    bean TPF Noob!
    Feb 23, 2004
    86
    Niagara, Ontario
    I went to a shop the other day in search of a 49mm ND filter, and following the usual pattern, none were available, so the salesperson recommended the Cokin filter system
    Can someone tell me the pros/cons of this system over ordinary screw on filters? What's the initial cost of the holder assembly and such?
    Should I be worried about breaking filters since I like to climb rocks? With screw on filters it's not such a worry since I can just snap on a lenscap.
  2. jack
    jack TPF Noob!
    Jan 16, 2004
    250
    london
    hi
    i havent used them for years, but i remember they are prone
    to getting scratched easily.
    i dont know the price now for them ,
  3. Mitica100
    Mitica100 Moderator Staff Member Supporting Member
    Nov 11, 2003
    9,746
    43
    Ahwatukee, AZ
    I used to do a fair amount of rock climbing and lost a filter or two. If you're going to take a camera along, I suggest a small camera, too much weight being a problem. But if you must have a ND filter on, I would definitely go with the screw on type. Cokin is great but scratches very easily, besides it takes you more dexterity to handle a Cokin, since you'll have to take it and/or put it back in its plastic case. Have you looked at 49mm to 52mm step up rings? Then, you'll be able to use the 52mm size ND filters, which are abundant.
    Good luck.
  4. zio
    zio TPF Noob!
    Dec 22, 2003
    107
    cb2 2bp
    i've only tried the polarizer...not the best, but it gets the job done and its cheap
tell me about filters for photography
