something i dont understand
Discussion in 'Photography Beginners' Forum' started by klissarov ik, May 27, 2007.
  1. klissarov ik
    klissarov ik TPF Noob!
    Mar 31, 2007
    226
    Montreal, Canada
    so when im zooming through my lens, the further im zooming the bigger the F(for exemple f 4, f 5, etc..) gets and i cant put it under the number it shows but can above it... is this supposed to be normal or? i got my camera settings on Manual and my lens is a nikkor 18-200mm
  2. motcon
    motcon TPF Noob!
    Jul 18, 2003
    1,410
    usa. soon to be a euro boy.
    very normal for zoom lenses.
    edit:
    just tuck this away in your head: the larger the number of the f-stop, the smaller the aperture.
  3. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    The F number represents a ratio between the size of the hole in the lens and the focal length. Each lens has a maximum size that the whole can get. With some zoom lenses...the hole can't get bigger but since the focal length is changing (when you zoom)...the ratio is changing...therefore the F number changes. However, it's only the maximum aperture that changes. For example, you lens might be F4-5.6 which means that the maximum at 18mm would be F4 and the maximum at 200mm would be F5.6. If you set the aperture F8, the F number would not change as you zoomed.
    You can always set it to a higher number because that just means you are setting a smaller hole.
  4. klissarov ik
    Mar 31, 2007
    226
    Montreal, Canada
    so let's sat when i'm zoomed in all the way to 200mm, i can't go under f 5.6
    so that's normal from what i understand? just to be sure there aren't any problem with the lens..
  5. The_Traveler
    The_Traveler Completely Counter-dependent Supporting Member
    Dec 11, 2006
    18,339
    7,570
    Mid-Atlantic US
    normal
