Sony A300 vs Canon EOS 1000
Discussion in 'Photography Equipment & Products' started by SnoWolf, Dec 15, 2008.
  1. SnoWolf
    SnoWolf TPF Noob!
    Dec 15, 2008
    4
    Dear guys :)
    I have been thinking about to buy a new dslr camera, the question is which one? to be honest i have been thinking about two cameras Sony DSLR A300 and Canon EOS 1000, not talking about accessories etc ... If u just make a compare between the two cams, which one is better?
    Kind Regards
  2. skieur
    skieur TPF Noob!
    May 14, 2007
    5,076
    203
    Canada
    Tilt screen, live view with fast autofocus, and Minolta, Sony, and Zeiss lenses are the advantages to the Sony A300. I am not familiar with the EOS 1000, which probably has a different name here.
    skieur
  3. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    I believe the EOS 1000D is the Rebel XS.
    Not really a fair question. A DSLR is part of a system and you should give that system a good look when choosing a camera...because you will be choosing that system as well.
  4. dascrow
    dascrow TPF Tech Staff Member Supporting Member
    Nov 10, 2008
    284
    43
    Sunny Alamogordo, New Mexico
    I have a Sony A300 and so far I'm really pleased with the results. I'm a newbie and still learning. For my needs it's been a great camera.
  5. SnoWolf
    SnoWolf TPF Noob!
    Dec 15, 2008
    4
    Thanks guys for giving me your thoughts.
    btw...
    http://www.dpreview.com/reviews/specs/Canon/canon_eos1000d.asp
  6. SnoWolf
    SnoWolf TPF Noob!
    Dec 15, 2008
    4
    Bro, i dont mean to talk in general... i just wanna make some kind of a compare between the two cameras. hopefully u understand me well.
  7. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    I get where you were going...I was just trying to steer you in a better direction ;)
    Really, most of these cameras are very similar...with small differences. It's like asking whether you should get a Toyota Camry or a Honda Accord...a Ford 1/2 ton or a Chevy 1/2 ton...a Coke or a Pepsi.
    In this case, I think the biggest difference is that the Sony has built-in stabilization while the Canon doesn't. The Canon however, is part of Canon's system, which is very good.
    The standard advice in this situation is to hold both cameras and use them a little bit. The one that feels better to you, is probably the best choice.
  8. SnoWolf
    SnoWolf TPF Noob!
    Dec 15, 2008
    4
    Thank you for the reply, and be sure i got your point and i understood which direction u were talking about. :)
    btw, I think both cams has Live View option or ... ?
  9. wharvey86
    wharvey86 TPF Noob!
    Nov 14, 2008
    24
    I have an a300 and love it! Features are real easy and fuunctional, the tilt screen is cool (even though i now realize i prob use it alot less than i thought i would !) the autofocus is very fast and most importantly it takes nice pictures!
  10. skieur
    skieur TPF Noob!
    May 14, 2007
    5,076
    203
    Canada
    Buying into a system is often mentioned when considering a camera, but in a lot of cases it is meaningless. Manual film lenses were replaced by automatic film lenses. Lenses without autofocus motors were replaced by lenses with autofocus motors. Some lenses used for film were replaced by lenses designed for digital. The quality of lenses has also improved as well as size improvements.
    If they reduce the chip size and improve the image quality at the same time then lenses and camera bodies will get smaller. Bottom lines is that lenses are becoming more consumable, rather than lasting for a very long time.
    Also relevant to the lens/system issue is that if you are not planning on buying a large number of lenses and system accessories, then it really does not matter.
    skieur
  11. dEARlEADER
    dEARlEADER TPF Noob!
    Apr 9, 2008
    1,312
    Canada
    meh... the ability swap lenses with buddies... the longevity of RAW format support... the quickness of RAW format development for third party applications... the ability to use a wider range of lenses, accessories.... the volume and availability of the used market are all things to consider when going with a system...
    you may think you'll only buy one body and a lens or two, but you are closing doors if you become hooked...
    the system matters...
  12. Frequent Traveler
    Frequent Traveler TPF Noob!
    Jun 1, 2005
    154
    I'd choose the Sony a300. It has anti-shake/"super steady shot" tech in the body so every - that is every single pea-pickin' lens used - is anti-shake. From primes/normal lenses to macro lenses to tele-zooms to super-zooms - every single lens. So, your 85mm f1.4 (already pretty fast) Carl Zeiss lens is also anti-shake allowing for better low-light performance. Nice.....
    I agree with the need for a solid system - it's frustrating when you're trying to find something and discover it's simply not available.... as in, "where are those Sony T/S lenses again? Ohhhh, we don't have those...." Arrghhhhh!
    However, with a photographic system there are MANY variables to consider. Not the least of which is availability of a good selection of camera bodies, lenses, and flash-guns.
    Fortunately, all of the 5 major manufacturers Canon, Nikon, Olympus, Pentax, and Sony(Minolta!!!!), CURRENTLY have adequate lens selections and most have adequate flash-gun options.
    I use "adequate" b/c, honestly, how many people are really going to buy a 600mm f4 super-telephoto or a 24mm Tilt/Shift lens or a 16mm fish-eye? Seriously?
    Yea, not many.
    How many people will buy a "standard" zoom or a 70-300mm - nearly all. In fact, some of those people may even eventually buy a fast 24-70mm or 70-200mm and some fixed-focal length "gems" (be they macro/wide/portrait/tele). Which company offers those kinds of lenses? Yup, all of them.
    My point is that most photographers lens needs are already present in the Big 5 line-ups.
    For flash-gun needs, again most photographers needs are met in the Big 5 line-ups - though Canon and Nikon are light-years ahead.. ;D
    So, how much lens/flash-gun over-lap is necessary to say a system is "adequate"?
    This is why i think the Holy Grail "Whole-System" argument is not as thoroughly valid as it once was simply b/c MOST photographers NEEDS are met and all the Big 5 are expanding their line-ups.
    Anyway, i believe every one of the Big 5 manufacturers offer some incredible camera value today and for not a lot of money.
    Which one is "best" for you depends on your personal handling preferences.
canon 1000d vs sony a300
sony a100 vs canon 1000d
sony alpha a300 vs 1000d
