Sooo i decided to try a water drop pic too....
Discussion in 'Photography Beginners' Forum' started by cosmoepic, Jan 28, 2009.
  1. cosmoepic
    cosmoepic TPF Noob!
    Dec 30, 2008
    218
    manassas, va
    I've seen numerous posts about water drops (RyanWard inspired me) and I realized I've never tried to shoot one, and lemme tell you...
    it took forever.
    i took over a hundred shots and got this one and another, this was my fav of the two. I know the "splash up" drops are a bit out of focus but i was doing this with a bottle of visine as a dropper then reaching down to shoot the pic standing about the vase. Ridiculous. haha
    C&C?
    [​IMG]
  2. MBasile
    MBasile TPF Noob!
    Apr 30, 2008
    362
    Sunnyvale, CA
    looks great minus being a bit out of focus, but I guess thats something that just takes practice (I've never even tried one of these shots!) How did you set up the lighting?
  3. cosmoepic
    cosmoepic TPF Noob!
    Dec 30, 2008
    218
    manassas, va
    used flash and a white light to the right with a poster board behind to bounce off of i have another one thats more of a stream of water coming back up ill post that in a moment too
    thanks for the kind words though
  4. zubair851
    zubair851 TPF Noob!
    Oct 24, 2008
    18
    nice shot... why don't you sharp (photoshop) it a little...
  5. LaFoto
    Feb 1, 2004
    34,813
    817
    Lower Saxony, Germany
    Well, that splash up ought to have been FULLY in focus. That's essential for these photos. Only a fraction out of focus and they no longer work.
  6. cosmoepic
    cosmoepic TPF Noob!
    Dec 30, 2008
    218
    manassas, va
    heres the second one i took more in focus:[​IMG]
    how do you get the focus to be sooo sharp on the drop?
  7. LaFoto
    Feb 1, 2004
    34,813
    817
    In my experiment, I had the tap keep dripping all the time (look up the set-up in the links I provided earlier), so I could manually focus on the droplet and it's "landing space" ... with the lens in its macro position, I only had a DOF of maybe 5mm, too. And it worked well on one day, and absolutely NOT on the next, when I seem to have had a "crick in the eye" and couldn't focus properly at all... :roll: ;)
  8. cosmoepic
    cosmoepic TPF Noob!
    Dec 30, 2008
    218
    manassas, va
    got ya ill look into it, how does the 2nd pic look? i think its alittle "cleaner" than the other.
    if you read above i had the cam as focused as i could while holding a bottle of visine above the vase counting to 5 then taking the shot on 5
    it was miserable and im sure i looked like a moron doing it, but for my first attempt at this type of photography im happy
  9. LaFoto
    Feb 1, 2004
    34,813
    817
    I understand why you are happy, and I would have been happy, too, more even with the second, as it is more in focus.
    (And no sharpening in PP will "save" that first one...)
    At first, also I tried to jump to and fro between dripping out of something into something and the camera and it did not work, until I started playing in the kitchen with the tap dripping continually for me, so I could stay with the camera and shoot.
  10. LaFoto
    Feb 1, 2004
    34,813
    817
    Oh, and with regards to composition ... it really depends on what you want to go for: when I took mine, I was also interested in seeing what effect the droplets would make on the surface and the rings they would create, and I hope to get most of those effects into my frame, hence I tried to keep the landing droplet in the middle, so the circles would not be cut off by either side. But if you take other effects of the dripping for more important to you, you may as well compose your pics the way you do, leaving the righthand side ALL empty.
  11. TheUndisputed
    TheUndisputed TPF Noob!
    Dec 24, 2008
    173
    Kennesaw, GA
    The second one is better. I would have kept doing it until there was a larger separation between the back splash and the droplet. Other than that, pretty good shot. Oh yeah, it needs more light. Sort of under exposed.
