Soulmates
Discussion in 'Critique Forum Archives' started by danalec99, Aug 7, 2004.
  1. danalec99
    danalec99 TPF Noob!
    Mar 14, 2004
    8,345
    68
    [​IMG]
    ::edit:: I changed the title
  2. vonnagy
    vonnagy have kiwi, will travel...
    Sep 8, 2003
    3,758
    26
    -36.855339, 174.762384
    I like this daniel!
    1. The sky is really perfectly exposed
    2. You have an interesting subject - not your typical panarama. I like these telescope fellas.
    3. BW - you have chosen wisely ;) very nice.
    The probably with landscapes, is that you often underexpose the sky to get the detail and the forground is a bit too dark then (happens to me all the time). Here the darkness, though atmospheric, makes it hard to see whats going on.
    Also you have centered the subject in the center of the photo, it seems to divide into halves. However, i am noticing the cloud pattern seems to come at angles directly in the center of the picture as well, so maybe its not so bad.
    Do you have any other from the series? Thanks for sharing :)
  3. terri
    terri Administrator Staff Member Supporting Member
    Sep 2, 2003
    27,379
    2,840
    In the mental ward of this forum
    Love it! Maybe the best work I've seen from you so far. Keep up the good work!!! :D
  4. danalec99
    danalec99 TPF Noob!
    Mar 14, 2004
    8,345
    68
    Thanks Mark, Terri :)
    Mark, I tried to have them off-sided, but did not like the frame. I prefer it centered with the lens that I used. If it was a different lens, then it would have been another story!
    Yes, the foreground is tad dark (wish it weren't), but it is not so bad on my monitor. 10 minutes after the shot was taken, it started drizzling.
    I've posted couple of other frames from the same series in the Photo Gallery section.
