SP or LP recording
Discussion in 'Off Topic Chat' started by digitalrightnow, Dec 22, 2006.
  1. digitalrightnow
    digitalrightnow TPF Noob!
    Aug 31, 2006
    52
    I just want to know if someone can explain the difference between SP and LP recording? I know that SP is 60 minutes and LP is 90 minutes? but what are the other major differences, and how should I decide which format to use? I am using minDV tapes, if this is a determining factor.
  2. Corry
    Corry Flirtacious and Bodacious Supporting Member
    Feb 5, 2004
    21,168
    109
    North Central Illinois
    I always thoguht it was slow play and long play...I'm sure slow play is better quality....
    ...clarinetjwd is a recording major, I'm sure he knows! :p
  3. clarinetJWD
    clarinetJWD The Naked Spammer Staff Member
    May 11, 2005
    5,787
    97
    Houston, TX
    so do you, so it would seem! :D
  4. Corry
    Feb 5, 2004
    21,168
    109
    I was right? Sweet! I rock!
  5. guitarkid
    guitarkid TPF Noob!
    Jun 26, 2006
    231
    chicago
    SP is much better quality than LP. i never use LP, then again, being in the audio engineering field, as well as video production and photography, you would never sacrifice quality for anything. Sure, you get longer record times with LP but it's not worth it to me, also, LP has tendency to put more wear and tear on your recording heads over time. SP works by having the tape pass over the recording heads at a faster rate, thus decreasing the recording time since more tape is used. The faster the tape passes over the recording heads, the better the quality. Some recoording studios that have used, or still use, analog tape in recordings have decks that record so fast, it almost looks like the tapes are in slightly fast-forward mode, resulting in the best possible recordings. Yes, studios do still record using tape as opposed to the ever-popular digital. This holds true for both audio and video.
