Speedlight confusion
Discussion in 'Photography Beginners' Forum' started by tom.ganc, Oct 19, 2008.
  1. tom.ganc
    tom.ganc TPF Noob!
    May 17, 2008
    155
    Manchester, UK
    Hi there
    I'm thinking about getting Nikon speedlight and I need to decide between SB600 and SB800.
    I'm going to use it as on camera bounced flash and off camera sometines (on sync cable). Could you tell me the biggest difference between those two flashes please? I know than SB800 supports fully Nikon CLS (SB600 can't work as commander flash) and they have difference in power aswell.
    I don't want to spend more than I have to.
    Thanks
  2. Phranquey
    Phranquey TPF Noob!
    Feb 16, 2008
    1,527
    11
    Dayton, OH
    You would probably be OK with the SB-600, it's a good flash, but I would recommend the 800 if you can. I'm always of the opinon to get a little more than you think you will need. It's better to have it and not need it then the other way around.
  3. tirediron
    Jul 8, 2005
    41,108
    12,493
    Victoria, BC
    You're correct on the differences between the 600 and 800. I agree with Phranquey's suggestion about getting more than you need, if you can. Don't forget to look for used.
  4. Phranquey
    Phranquey TPF Noob!
    Feb 16, 2008
    1,527
    11
    Dayton, OH
    Absolutely. Everything I have was bought used.
    Another thing in favor of the SB800 is the ability to add the fifth battery, which is really nice for cycle times.
  5. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
    SB600 doesn't support using a sync cable I don't believe. You can get around this with a hotshoe adapter, but it's good to be aware.
    I dislike Ken Rockwell, but here is a valuable comparison:
    http://www.kenrockwell.com/nikon/sb600vs800.htm
