Spot Metering Question ( XSi )
Discussion in 'Photography Beginners' Forum' started by j-digg, Apr 15, 2009.
  1. j-digg
    j-digg TPF Noob!
    Jan 3, 2009
    476
    15
    Minne-snow-ta
    I'm not 100 percent here.. but pretty sure that when I use spot metering it never seems to take my reading from the AF point I manually chose, but always from the center dot. So do I have to take the reading from the center spot and then recompose or is there a way to meter it from the desired location of focus? I'll mess around with it as soon as I get home too, just to make sure I'm not crazy. :lol:
  2. HoosierJoe
    HoosierJoe TPF Noob!
    Dec 23, 2008
    47
    Indiana
    In my 30D manual it shows that spot metering in the center 3.5% of the viewfinder. They have a diagram showing the coverage. I don't know about the Xsi, so have a look at your manual. However I believe that the movable or variable spot metering is only on some of the 1Series Canon's.
  3. licepic
    licepic TPF Noob!
    Feb 25, 2009
    Are you pressing the "Set" button after you have selected the AF point? The "Set" button will reset the AF point back to the center. Just manually select the AF point you want and exit.
  4. j-digg
    j-digg TPF Noob!
    Jan 3, 2009
    476
    15
    Minne-snow-ta
    Finally found my manual again, and Hoosier, you were right.. It tells me it reads from the center, so I will have to exposure lock then recompose.
    /closethread
  5. LarryD
    LarryD TPF Noob!
    Feb 6, 2009
    614
    Mojave Desert
    Perfect.........:thumbup:
    I usually always use partial or spot and meter on the main subject, lock, recompose, focus and shoot..
    If the photo is important, I may AEB on each side...........
eos xsi spot metering
spot metering in xsi
spot+metering xsi
xsi metering
xsi spot focus
