Spot Stuck on Camera?
Discussion in 'Beyond the Basics' started by S40T5Lover, Nov 13, 2008.
  1. S40T5Lover
    S40T5Lover TPF Noob!
    Jun 24, 2008
    27
    Dawsonville, GA
    Alright, so my camera has some sort of spot somewhere stuck on it. I know its not on my lenses because I switch lenses and its still in the same spot... What can I do..?
  2. Lyncca
    Lyncca TPF Noob!
    Jan 7, 2008
    1,881
    5
    Fort Worth, TX
    Have you had someone look at your sensor to see if it needs to be cleaned?
    I have the same problem with D70s, but it isn't on the sensor, you just see it on the viewfinder. It makes me absolutely nuts, but the camera shop said it would have to be completely disassembled and they didn't recommend doing it for something that wouldn't show up anyway.
  3. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    Do you mean that there is a spot showing up in the images?
    It's 95% likely that this is dust on the sensor...and your sensor needs to be cleaned. This is just a fact of life with a DSLR camera.
    It's not hard to do, but you do need to be careful about it. Search the forum for 'sensor cleaning' or failing that, search Google.
    *edit*
    Yes, if you can see the spot when looking into the camera, then it's not on the sensor...but it most likely won't show up in the images, so try to ignore it.
  4. roadkill
    roadkill TPF Noob!
    Jan 26, 2008
    392
    Atlanta GA
    I had that and blew off my sensor with a little puff of air (from a bulb not my mouth). It was gone
  5. S40T5Lover
    Jun 24, 2008
    27
    Dawsonville, GA
    I might also add this is the third time this has happened...
    The sensor is the mirror inside? or the thing above that....?
  6. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    The sensor is behind the mirror and the shutter, you can't see it unless you activate the cleaning mode which flips up the mirror and holds open the shutter.
    When you are looking into the viewfinder, you are looking into some mirrors, then onto the main mirror, then out the lens. The light from the lens can't get to the sensor at this time because of the mirror (and the shutter). So anything that you see when looking into the viewfinder, is either on the viewfinder, the mirror, the lens or outside.
    When you press the shutter release button, the mirror flips up and then the shutter opens so that the light can hit the sensor. The viewfinder goes dark while the mirror is up.
    Because of this, anything that is on the viewfinder or mirror will not show up in the images. But dust that is on the sensor, can't be seen in the viewfinder but does show up in the images.
  7. Lyncca
    Lyncca TPF Noob!
    Jan 7, 2008
    1,881
    5
    Fort Worth, TX
    Yea, that is what the dude at the camera store said too. It sounded just as complicated as when you said it. LOL
  8. jbushee
    jbushee TPF Noob!
    Jun 10, 2008
    53
    Lockhart, TX
    There's usually a menu item for sensor cleaning. Select it, remove the lens and blow out the inside (I hold the camera with opening down so dust doesn't resettle :)) and power off when done.
    Easy peasy
  9. andrew99
    andrew99 TPF Noob!
    Jan 23, 2008
    672
    Toronto, Canada
    I had a large spec in my viewfinder recently (only in the viewfinder, not on images). Getting rid of it was as simple as removing the lens, pointing the camera at the floor and blowing some air inside the camera body with a bulb blower. Never blow into the camera with your mouth and don't use those cans of compressed air!
  10. danjchau
    danjchau TPF Noob!
    Feb 27, 2008
    160
  11. Joves
    Joves No longer a newbie, moving up!
    Dec 14, 2007
    2,399
    21
    Flagstaff/Az
    That is what Im thinking as well. You can try using a bulb blower to get it off. Remember this always never use canned air to clean your camera, most canned air is not that clean.
