Garbz
- Joined
- Oct 26, 2003
- Messages
- 9,713
- Reaction score
- 203
- Location
- Brisbane, Australia
- Website
- www.auer.garbz.com
- Can others edit my Photos
- Photos NOT OK to edit
Err I don't think you understand how things work on the whole. The resident program is just a quick management tool and all calibrators come with them. What it does is ensure the correct correction curves are loaded into the video card / monitor LUT assuming it supports hardware lookup tables. Unless you're doing something very strange with your calibration (like trying to force a monitor to be sRGB when it's not which is definitely not the right way to go about things), then things run like this:
- The resident program checks to ensure the correct curve is loaded into the videocard / monitor LUT, as well as ensure the correct profile is set in windows.
- The video card's output will ensure consistent colour across the tonal range and set your white point to the one you selected. If you have a monitor with hardware lookup table then this is handled by the monitor and the video card output remains as per normal. This only provides consistency and temperature nothing more.
- The software you are using is still required to recognise the colour profile to know just how red that value of red is and what it actually should be. What the software will assume is that your monitor colour is consistent (something the video card LUT is ensuring).
Short answer: All calibrators come with a little program like that. All software needs to have calibration turned on. This is far more important if your monitor doesn't have an sRGB gamut.
