Statue C/C
Discussion in 'General Gallery' started by dslrchat, May 19, 2008.
  1. dslrchat
    dslrchat TPF Noob!
    May 5, 2008
    274
    I took many of this, was real hard to try and get full exposure with out the blow out.
    This was taken at night with a lot of spot and lamp posts around.
    Shadows everywhere.
    [​IMG]
  2. Wyjid
    Wyjid TPF Noob!
    Mar 28, 2008
    836
    Muskoka Canada
    cool shot. i have a couple of suggestions that i hope can help.
    if you have a lot of light and dark areas i'd use that to your advantage. i like that area around her hands knees and feet. lots of cool shadows and lines. that could be a cool contrasty picture if taken on it's own. mabey just on of the hands. then accentuate that cantrast. if you want the whole image, i'd just under expose it. then your whits wont blow. and you'd get a crisper image. again, focus on the darker mood with lots of shadows. or if you want, PP with Image, Adjustments, Shadows/Highlights and then remove some shadows. that way your highlights wont be blown.
    as it is i like the lighting of the scene. it would be fun to shoot. you live near by? if so play around with it. i like it a lot.
  3. delizo23
    delizo23 TPF Noob!
    Nov 28, 2007
    229
    South Jersey
    i little blurry
  4. Wyjid
    Wyjid TPF Noob!
    Mar 28, 2008
    836
    Muskoka Canada
    of course it is. :er:
  5. dslrchat
    dslrchat TPF Noob!
    May 5, 2008
    274
    Thank you for the comments, I will go back and try some more (with my tripod this time)
  6. tirediron
    Jul 8, 2005
    38,454
    11,266
    Victoria, BC
    Very nice shot, and an ideal candidate for a High-Dynamic Resolution (HDR) Merge. If you have either Photoshop CS2 or or CS3, or PaintShopPro XII, simply take a series of exposures starting off with the brightest or darkest areas, and work your way to the other end of the scale in two stop increments, and the software will use those images to generate a composite that will have most of the dynamic range of the series. A quick Google of "HDR Merge" will give you tons more info.
  7. Wyjid
    Wyjid TPF Noob!
    Mar 28, 2008
    836
    Muskoka Canada
    it would look cool, but you would lose all the feeling of the scene.
