STE2 / Pocket Wizard
Discussion in 'Photography Equipment & Products' started by Groupcaptainbonzo, Mar 16, 2007.
  1. Groupcaptainbonzo
    Groupcaptainbonzo TPF Noob!
    Nov 9, 2006
    463
    Turners Hill, West Sussex, UK.
    :confused: I want to trigger my 580EX remotely from my EOS 400D. I have been advised to use a "Pocket Wizard". This would rely on me getting a PC adaptor for the 580EX. It appears to me that the Canon STE2 has been designed to do the same job.:thumbup:
    1) Am I correct in this assumption?
    2) Are there any advantages to going with the "Pocket Wizard" set up over the STE2 ?
    3) Is there a cheaper solution, or do I just have to sell the wife and kids into slavery? :blushing:
  2. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    You could shoot Nikon :sexywink:;)
    I'm actually not sure about pocketwizards, STE2's and whatnot, since I can fire my SB-600 wirelessly anyway.
  3. Big Mike
    Dec 16, 2003
    33,864
    1,822
    Edmonton
    Yes, I believe you will need an adaptor to connect the P.W. to the flash. Shouldn't be too expensive, not compared to the price of the P.W.s anyway.
    Yes, the ST-E2 will fire the flash wirelessly without any adaptors.
    Here are the main differences, as I see it. The Canon wireless set up will let you keep the E-TTL metering, just like if the flash is on the camera. You can use up to 4 flash units and you can even set the power ratios from the master unit. The short coming of this system is that it's an IR signal. In some situations (outdoors) you may need line of site from sender to receiver for them to trigger. Indoors, the signal will bounce off the walls etc.
    The Pocket Wizards are said to be very reliable. They are a radio wave signal so they should fire from just about anywhere. I think the range is also greater than the Canon IR system. The problem with this is that you loose the E-TTL metering and you have to set the flash power manually.
    Either way, these two options are not cheap. Rather than buying the ST-E2, you could get another 580EX or another model (550EX, 420EX, 430EX) and use it as a slave...to your 580EX. Your flash can do everything that the ST-E2 can do.
  4. Groupcaptainbonzo
    Nov 9, 2006
    463
    Kinda thought so. The ST-E2 is the cheaper option of the three. But it will all have to wait for a week or two as I am low on funds at the Moment. Thanks again.
    Tim.
