Step ting for R72
Discussion in 'Photography Beginners' Forum' started by photong, Apr 25, 2007.
  1. photong
    photong Typo Queen
    Aug 7, 2003
    1,235
    5
    Tornto, Ontario
    I want to get an R72 filter for my D70s (67mm)
    But I also want to use it for my Ae1/A1 lenses (52mm)
    What is the best way to go about a step ring.
    Should I get a 67mm-52mm step down ring (I found some on Ebay)
    Or should I try for a step up ring for 52mm-67mm? (also some on Ebay)
    Which would be the least expensive?
  2. Groupcaptainbonzo
    Groupcaptainbonzo TPF Noob!
    Nov 9, 2006
    463
    Turners Hill, West Sussex, UK.
    Get the bigger filter and step it DOWN to the smaller lens. That way you will reduce the likleyhood of Vignetting.
  3. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    Not step down, step up. You want to go from the 52mm TO the 67mm.
  4. 250Gimp
    250Gimp TPF Noob!
    Oct 3, 2006
    1,031
    Chelsea, Quebec
    Most desriptions should tell you exactly which end is the male or female end. You want a 52mm male end, and 67mm female.
  5. photong
    photong Typo Queen
    Aug 7, 2003
    1,235
    5
    Tornto, Ontario
    So I'm looking for a 52mm-67mm right? And this will not cause a vignette?
  6. xfloggingkylex
    xfloggingkylex TPF Noob!
    May 5, 2006
    1,292
    Frederick, MD
    always step up. Stepping down causes vignetting because, well just the nature of putting a smaller ring on the front of your lens, instead of beign 67mm in diameter it would now be 52mm, so you lose that extra 15mm.
    And unless it is a really wide angle you shouldn't get vignetting.
  7. photong
    photong Typo Queen
    Aug 7, 2003
    1,235
    5
    Tornto, Ontario
    Thank you ;)
