Sticking zoom control on 18-55 Nikon
Discussion in 'Photography Equipment & Products' started by Gnat5680, Jan 25, 2010.
  1. Gnat5680
    Gnat5680 TPF Noob!
    Jan 23, 2010
    33
    Minnesota
    Ok, so First off, Not sure if this is the right place, but it seemed fitting.
    So I have been shooting with my AF-S 18-55mm VR lens since the day I bought my camera. It worked great till it decided to kill it's self. It took a dive into a table and it wasn't pretty, lets leave that there. I noticed that the zoom was really tight and barely turning (obviously we know why). But After shelling out the $150 again or the same exact lens, I am noticing that this lens is slowly getting that same feeling.
    Around the 35mm markings, it gets alittle binding and then frees up again. It also is not getting a crisp focus on Auto. It seems to be off by a fraction of a turn on the focus. This lens HAS NOT taken any drops or falls and I have been the only one to use it. So Now it has me worried about whether it is Nikkor lenses (No problems with my other Nikkor Lenses) or if there is a care issue at hand. I keep them well taken care of in a camera case (soft case) and I keep a desicant in there to keep it dry. I clean the lens often and am never rough with it...
    Does anyone know what could be casuing this issue and if Nikon will replace the lens? I think it may be out of warranty so I doubt they will do anything, But Its worth a check.
    Thanks!
  2. PatrickHMS
    PatrickHMS TPF Noob!
    Oct 29, 2008
    1,411
    Metro Atlanta
    If you bought the lens new, retail, and still have your receipt, you might can get some warranty from Nikon.
    If I am not mistaken, I believe it to have a 5-year warranty, and you lens is probably newer than that.
  3. Gnat5680
    Gnat5680 TPF Noob!
    Jan 23, 2010
    33
    Minnesota
    Oh ok, I thought it was some small bogus 1 year warranty. Yes, it is newer then that. I think it is about a year and a half old...
    Thanks! I will try calling them up in a bit!
nikkor 18-55 stuck at 35
nikon 18-55 stuck zoom
nikon 18-55mm lens zoom stuck
nikon lens dx 18-55mm jammed
nikon lens zoom stuck
