Still having trouble
Discussion in 'Beyond the Basics' started by EscapeTurn, Oct 15, 2005.
  1. EscapeTurn
    EscapeTurn TPF Noob!
    Sep 30, 2005
    85
    9
    Mid South
    I posted a few weeks back with a concern about my blurry pictures.
    I got very helpful feedback. Since then I've been experimenting with my camera, reading the manual, and trolling these forums. While I've learned a ton, I'm still a noob! :p
    I had the opportunity to shoot my dogs running in the same low light as before, at about 7:30 AM.
    I did just as you advised. I rolled the dial to P, set the ISO to 400 and I put the EV at 0 because anything higher washed out the image. The pictures did improve in clarity, but they weren't what I was hoping for.
    I'm trying to get down to the root of my problem. Any advice would really be appreciated!
    Edited to Add: They only run like this in the morning when it's cool, so unfortunately shooting them doing this around noon isn't really an option.
    Here are a couple examples:
    [​IMG]
    [​IMG]
    [​IMG]
    Thanks in advance! :wink:
  2. Unimaxium
    Unimaxium TPF Noob!
    Nov 13, 2004
    2,689
    22
    Northeastern University, originally from Philly
    It's motion blur... the subjects are moving too fast for the shutter speed. In the case of the first image, it also seems you were panning the camera while the shutter was open, causing the whole image to be blurry. The simple fact is your camera might not be able to capture images with a fast enough shutter speed in the kind of lighting you're shooting in. The only other thing I can think of to try is to use the flash. If the subjects are at a good distance (not too close, not too far), then your images might come out better.
  3. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    Turn the flash on and put it in action mode. You may need a camera with a faster lens and/or higher ISO if you can't do it when there is more light.
