Still Life
Kevin D Burns
I was unsure how to edit and add a post with the image.
I
finally
used a tri pod. manual focus used to give a 2D look to image.
now I just have to remove the shadows or use a black BG. LOL.
Thanks
Well you could but im not sure I would. The shot and the shadows blend into a very 1950ish kind of cinema type photography. The shadows on the wall are dramatic.
If for still life you want a black background try a couple of pieces of black matt board. Not to awfully expensive and fairly tough stuff. You might want to get a cheap bottle of cheap craft paint to touch up any nicks you get otherwise it should last you a lifetime.
Thanks for the info, i am making a photo box but was using black foam. The black foam was getting sparkles from the lighting. I will try some black matt board as suggested.
Thanks for the support on my BG as I was sure the shadows would catch fire with people. Thanks.
