stripped tripod threads on my 5D!!!! help!!!
Discussion in 'Photography Beginners' Forum' started by shortpballer, Sep 21, 2009.
  1. shortpballer
    shortpballer TPF Noob!
    Aug 1, 2009
    664
    12
    San Diego
    I just picked up a 5d for an amazing price. However the threads on the bottom where you connect a tripod are stripped. How much would it cost to fix this? Can I do it myself? What needs to be changed etc. I wouldn't care but I want to put a grip on it. Please help!!!
    Eric
  2. Gersen
    Gersen TPF Noob!
    Sep 22, 2009
    A pain to be sure.
    Have you thought about using a heli-coil or other thread insert repair? Get them from your local hardware place or order some online.
    The thread is a 1/4-20 for a 5D
  3. PhotoXopher
    PhotoXopher TPF Noob!
    May 27, 2009
    3,475
    Depending on how bad they are you could try a tap as well and re-thread it.
    Available at pretty much any hardware store.
  4. shortpballer
    Aug 1, 2009
    664
    12
    San Diego
    I don't know if I feel comfortable drilling into my camera. Isn't there a way to buy a replacement part? Like replace the bottom part? It is actually the outer 2 or 3 threads that are bad, so I can put a tripod on but it only gets about 2 or 3 turns. So I don't know if this is safe or not...
  5. PhotoXopher
    May 27, 2009
    3,475
  6. shortpballer
    Aug 1, 2009
    664
    12
    San Diego
    NOYZE- that is just a link to the tool kit to do it. The threads are pretty bad. They are almost filed down to nothing... so my tripod will slip into the threading about half a cm or so then it will start threading to the inner threads. Are you sure this can fix that? They aren't just cross threaded. Its almost as if there are no threads at all.
  7. max3k
    max3k TPF Noob!
    Jun 11, 2009
    497
    10
    send it to me, i'll send you my XS which has perfect threads for a tripod. i dont use a tripod that often so i'll try and live with it
  8. syphlix
    syphlix TPF Noob!
    Jul 23, 2009
    687
    NYC
    shrug
    why not take it to a camera repair shop and ask them
  9. KmH
    Apr 9, 2009
    40,742
    5,588
    Iowa
    Or a local machine shop. Sounds like a heli-coil or similar may be needed.
  10. jbylake
    jbylake Dodging the Men in Black
    Jul 23, 2009
    729
    35
    State of Confusion.
    My thoughts exactly. Hi Tech machine shops deal with much more complicated operations to save threads on incredibly complex items in order to repair/extend their operational life. This would be a very simple fix, if you can find one that will do it. It might get a little expensive. Machinists, expecially very talented one's or tool and die makers labor is expensive. But I'd bet you could get it done for under a hundred. Maybe less if you've got a friend in the machining/engineering field.
    J.:mrgreen:
  11. musicaleCA
    musicaleCA TPF Noob!
    May 23, 2009
    2,303
    Vancouver, BC
    Probably under a hundred. I've had my hot shoe replaced for under a hundred CAD (had to have one of the screws drilled out; thank goodness it wasn't the screw that carried the ETTL information).
  12. DennyCrane
    DennyCrane No longer a newbie, moving up!
    Sep 11, 2009
    1,375
    34
    The arctic North Coast
camera threads for tripod stripped
replacing stripped tripod mount
threads on my camera tripod stripped
