Strobe begginer . . . need some suggestions
Discussion in 'Photography Beginners' Forum' started by VltnDennis, Apr 30, 2010.
  1. VltnDennis
    VltnDennis TPF Noob!
    Nov 2, 2008
    144
    Sup guys well i already have a nikon sb600 and some tripods. Im going to order some wireless trigger out of ebay but now the question is , im looking for a cheap flash just to get a lil more light since my main will be the sb600. take in mind that im only doing this as a hobby. I saw a vivitar flash for like $40 on ebay now is this any good?
  2. Felix0890
    Felix0890 TPF Noob!
    Oct 2, 2009
    472
    Miami , FL
    The vivitars are great for what you want. I myself use a Canon as my main flash with Vivitar 285HV's as my fill flashes.
  3. RyanLilly
    RyanLilly No longer a newbie, moving up!
    Aug 27, 2007
    1,478
    8
    St. Louis, Missouri, USofA
    What Vivitar model was it? The 285HV is a very useful flash, normally for about $90 new, there is also the old 285 and 383? I think, not sure on the last model number, but those can be found cheaper used, because the trigger voltage is to high and will damage modern cameras, however they work fine with most off camera triggers.
    The Vivitars are built pretty cheap and recycle time is slow at full power, but they are a very good bang for your buck. I have several and they work well for my needs.
  4. VltnDennis
    Nov 2, 2008
    144
    theres a sf 4000 model , thats around $40 . . . i thought i might work pretty nice for a "fill" flash
  5. Goontz
    Goontz TPF Noob!
    Jul 17, 2009
    1,275
    Austin/Houston, TX
    Why not just stick with the single off-camera SB-600 that you already have, until you really understand and know what you're doing with "strobist" lighting, before moving to two off-camera flashes?
  6. gian133
    gian133 TPF Noob!
    Mar 2, 2009
    214
    South East Michigan
    vivitar will work fine....but make sure its a model with variable power.
    or just bump you budget up a bit to $75 ish and get the sb-24
    if you cant afford it at the moment the i would listen to Goontz^
    Just stick with 1 for now and get something better when your ready
  7. KmH
    Apr 9, 2009
    40,732
    5,587
    Iowa
    www.strobist.com
    Tripods will be limiting because they cannot be raised high enough.
    Light stands work a lot better.
    Here is an 8 foot light stand: Impact | Air Cushioned Light Stand, Black - 8' (2.4m) | LS-8A
    9.5 foot: Impact | Air-Cushioned Heavy Duty Light Stand - | LS-96HAB | B&H
    13 foot: Impact | Heavy Duty Light Stand, Black - 13' (4m) | LS-13HB
  8. VltnDennis
    Nov 2, 2008
    144
    I dont mind raising the budget a lil bit , any other options for around that price?
  9. VltnDennis
    Nov 2, 2008
    144
    anyone?
  10. table1349
    table1349 Been spending a lot of time on here!
    Sep 9, 2006
    4
    :thumbup: +1
    Have to agree. First you have to crawl before you can walk. Once you talk about multiple light setups you are either talking one of two things. Flat lighting, not really attractive or ratios.
    It is much easier to figure ratios if your strobes are consistent. For my strobist setup I have 2 580 EX and 3 Sunpak 383's All have the same guide number and all have variable output. Setting ratios is easy.
    Question for the OP. If you get a couple of manual use strobes to go with the sb600, how are you going to meter your shots. You won't have the luxury of TTL, you will have to shoot manual. Have you got a flash meter? If not is one in your budget?
    Yes you can chimp and take test exposure after test exposure and check the screen in the back. Subjects/models get bored easily while doing this.
    This would be a good place to start doing some reading. Strobist. It can take you a long way in getting started shooting and with gear to use.
  11. gian133
    gian133 TPF Noob!
    Mar 2, 2009
    214
    South East Michigan
    check this out...i just got one a few months ago
    Nikon Autofocus SB 25 (GN138) BOUNCE, SWIVEL, ZM, SHOE MOUNT FLASH - KEH.com
    and i wouldnt worry about the "BGN" condition
    i got one in "EX" which is just one step above BGN and it looks like it never came out of the box. brand new
    $72 i dont think you can go wrong
    Edit: and yes^^ do some (a lot) of reading on the strobist site....lots of good stuff on there to help you out
  12. --ares--
    --ares-- TPF Noob!
    Aug 17, 2009
    152
    I think you should just get an off camera cord and play with that for a while before you jump into multiple strobes.
