So ... in SU4 mode the SB700's will recognize that the main strobes just went off and that means they also need to fire as well. DO I have that right? I basically want one single big flash essentially all at once.
That's how I fire my speedlights (including an SB700) when mixed with strobes.
I typically just use one radio trigger on either a speedlight or strobe and put the rest in slave mode.
I only add more radio triggers if the positioning means they can't be optically triggered.
I do realize this isn't complicated enough, so your results may vary
Yes. SU-4 is Nikons built in optical slave mode.
They won't have the distance range that a set of Pocket Wizards will,but they're very reliable.
What I'm really worried about is the subject reacting to the flash, and eyes start to close, etc.
His main strobes are a Speedotron pack and head system.
