Strove vs Continuous
Discussion in 'Beyond the Basics' started by rCOSIO, Jul 16, 2010.
  1. rCOSIO
    rCOSIO TPF Noob!
    Aug 31, 2009
    134
    SoCal
    ***STROBE is what I meant up there ^, sorry***
    Sorry if I am repeating a questions guys, but wanted to updated my small home studio. I currently been using a couple of strobe's with umbrella's and even my 430's with remotes, but wanted to upgrade a bit ....
    This would be for a small home studio for portraits, either headshots or just some random fashion small photoshoots.
    My questions is, what should I upgrade to:
    Continuous Lighting w/Softbox OR Strobe's w/Softbox
    Thank You!
  2. bigtwinky
    bigtwinky No longer a newbie, moving up!
    Oct 6, 2008
    4,820
    285
    Montreal
    If its for a home studio, I'd stay with the strobe concept and get some flash heads that have modeling lamps, something like Bowens, Elinchrom and so on
  3. rCOSIO
    rCOSIO TPF Noob!
    Aug 31, 2009
    134
    SoCal
    Thanks for the reply, if you dont mind me asking ... why do you recomend strobe's aposed to continuous lighinting?
  4. ghache
    ghache No longer a newbie, moving up!
    Jan 25, 2010
    3,570
    295
    continuous ligning create so much heat.
  5. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    The problem with continuous lighting, is that you are reliant on the shutter speed as part of your exposure equation. If you are shooting static subjects with a static camera, then it isn't a problem...but if you are shooting subjects that might move, or you want to shoot hand held, then you need to be mindful of the shutter speed, if you want to avoid blur and maximize the sharpness of the photos.
    In order to get decent shutter speeds (with continuous lighting), you will likely need to use either very large apertures, rather high ISO or pretty powerful lights. Using large apertures is OK (if you have the lenses for it) but you won't always want to have a shallow DOF that comes with it. Using high ISO settings isn't ideal because of the digital noise. And using bright lights will often mean a lot of heat, which can be uncomfortable for you & the model, not to mention a possible hazard.
    Using strobes can solve most of those problems. Because it's a very short burst of light, you don't need to use the shutter speed to freeze movement. Usually resulting in crisp photos.
    And as long as your lights are powerful enough, you can use smaller apertures and low ISO. And while a hard working studio strobe will generate heat, it shouldn't be enough to make anyone uncomfortable.
  6. rCOSIO
    rCOSIO TPF Noob!
    Aug 31, 2009
    134
    SoCal
    Thanks for reminding me ... I forgot about this!
  7. rCOSIO
    rCOSIO TPF Noob!
    Aug 31, 2009
    134
    SoCal
    Awsome response. Thanks Big Mike. I'll go get some strobes and give my Canon 430's a rest for a while lol.
  8. rCOSIO
    rCOSIO TPF Noob!
    Aug 31, 2009
    134
    SoCal
    Last question guys ....
    What's a decent light for the background, kinda to wash out the white to assist in less post work? Anything in-expensive that works?
  9. c.cloudwalker
    c.cloudwalker TPF Noob!
    Jun 15, 2009
    5,394
    405
    An American in Europe
    For a home studio I would seriously consider the Alien Bees. They are cheap and quite decent so that if you ever get more serious, they could still be used in a better studio. They also have the Einstein now although they are sold under a different name and I don't know anything about them.
    The problem with continuous lights is that, as their other name suggests (Hot Lights) they get hot. Which means so does the model and modeling is hard enough without getting hot. And in a pro studio they are not economically advantageous. Their electricity use over time will cost you more than the price difference to go to strobes.
    But if you shoot very little in your studio, and mostly for fun, why not just use flash units? The Strobist way. I don't often recommend that way to go because it just doesn't look professional (and I believe that makes a big difference in how your business is seen) and I also don't see the point of having a bag full of flash units if you're trying to go pro since they are not designed for heavy use as in a studio environment.
    Other than that, flash units can be had used for next to nothing if you shop in the right places so you could get quite a few of them (plus their stand and light modifiers) for the price of 1 strobe.
  10. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    40,506
    15,225
    USA
    For low-cost background lights that will illuminate gray paper and boost it to white, something simple like the Morris slave strobes will work. Two of them, one on each side of the paper, would be nice to have. I think something from Morris might be exactly what you are after. These units have been produced for literally decades. I am surprised that they have never taken off, but then again, the company does not promote its products worth a damn, nor do they sponsor any photographers...
    "Photo Platter": Morris Mini Slave
    Here is a page from a really great USA brick and mortar and web-based store, Tallyn's, that shows information on the whole line of Morris flash units.
    Tallyn's Professional Photographic - MORRIS SLAVE STROBES
  11. Alpha
    Alpha Troll Extraordinaire
    Mar 15, 2005
    5,454
    41
    San Francisco
    The best advice I can give is to use the search function.
