Studio (flash) strobe
Discussion in 'Beyond the Basics' started by kburutto, Nov 10, 2005.
  1. kburutto
    kburutto TPF Noob!
    Nov 10, 2005
    i am trying to set up a studio at home.
    what do i need to look for in a flash strobe?
    thank you
  2. kburutto
    kburutto TPF Noob!
    Nov 10, 2005
    I understand that w/s (watts per second) in the strobe determents the strength.
    Dump question: can I put a stronger light (watts) in the strobe?
    ex: if my strobe is 320 w/s can i have a 300 watts light bulb?
  3. sparky
    sparky TPF Noob!
    Nov 9, 2005
    13
    Blackpool, UK
  4. kburutto
    kburutto TPF Noob!
    Nov 10, 2005
    thanks sparky
    but still want to know the answer to the question... :er: vbmenu_register("postmenu_326098", true);
  5. jstuedle
    jstuedle No longer a newbie, moving up!
    Jun 30, 2005
    4,889
    14
    S.E. Indiana
    First you will need to determine the size of your studio and the number of lights you plan to use. This will give you an idea of the power rating you will need to shop for. Determine your budget and if you will need your strobes to be portable, will they be used off location as well. I started out with photo-floods way back in the day. I have used multiple flash units with some success. ( 3 Sunpack 383's) I now use a couple Westcott Spider-lites and I like them a lot. Strobes will give you more light for greater DOF. I do a lot of animal and child portraits and the continuous light I use is less of a bother to critters and children, and the "what you see is what you get" quality of continuous lighting I find an advantage. At the low end of strobes, take a look at Alien Bee's. The sky is the limit at the high end.
  6. jstuedle
    Jun 30, 2005
    4,889
    14
    S.E. Indiana
    No, power is as much determined by the power supply in the flash head as the bulb.
